I have been unsuccessfully attempting to download Flash Player on IE and Mozilla. When i get to the "install" window on both browsers it says that download will commence once browsers are closed. When i close browsers i am unable to access Adobe without a browser opened.??
Hi, Do you have a link to the website that you are using? Does the message say that the Installation will proceed, instead of the download?
I'm not clear what site you are on to be receiving this message.
eidnolb
Download the executable installers from http://www.adobe.com/products/flashplayer/fp_distribution3.html and save them to disk, then close all browser windows and run the downloaded installers.http://www.adobe.com/products/flashplayer/fp_distribution3.html
Hi, I would like to add to what Pat posted and that is to make sure you download and SAVE to your Desktop the Uninstaller first
from here:
http://kb2.adobe.com/cps/141/tn_14157.html
Then download and SAVE the Installer for IE and the Installer for FF(plug-in) to your Desktop.
Once you have those on your Desktop, then Close all browsers.
Be sure to use the Administrator Account for this.
Check the system tray(area near the clock) and disable any instant messengers, like yahoo, msn, aol, etc.
Also you may want to Disable any Anti-Virus that you use as some can block the Install. Re-enable when finished with this.
Run the Uninstaller and when finished, Reboot(restart) your computer.
Then Run the IE Installer and then the FF Installer, when finished, Reboot.
Test each browser here and you should be able to see the Flash logo animation and the vs of Flash Player will be displayed.
http://www.adobe.com/software/flash/about/
If you have any questions, let me know.
Also you may want to print this out to make it easier.
eidnolb
I am having the same failure, fails to initialize. I will now follow your advice, saving uninstall and BOTH installs to desktop. Rebooting after each operation.
Wish me luck, am nearing throwing computer into firepit for warmth.
You can also find the uninstallers and full installers at http://forums.adobe.com/thread/909550
Make sure you download the correct executables (32-bit or 64-bit) for your system.
Hi Pat-
I have unistalled/re-installed with no result. I believe there is a compatibility issue between the latest (.63) Flash and Firefox 10. I’ve even updated to Firefox 11. Same warning….”update Flash NOW”…and when I try, “initialization failed”.
Hmmmmmph
Monty
And you downloaded the uninstaller / installers from the link I posted earlier? I don't think so; that message only appears if you use the standard installer.
B.t.w. what is your Windows version & edition?
Yes, I followed instructions to the letter. I'm getting pretty quick at it...I've used Reg cleaner/defrag/CleanUp/etc so my re-boot times are minimised.
And I always exit Malwarebytes, my virus software, before attempt.
Windows XP Home 2002 service pack 3. I've even established a clean restore point, since...after each failed attempt, I'm left with no flash player at all.
I'm downloading the 32 bit uninstaller from your link, a 229kb file. Saved in 'my downloads', or saved shortcut to desktop, browsers open, browsers closed, it's all the same.
"Failed to initialize"
No joy. I did find four NPSWF32.dll which I deleted. Had high hopes. Am reminded of the axiom that, if you keep doing the same damn thing expecting a different result...you may be a redneck. Or, was that a corrolary? Nevermind, I HATE FIREFOX now. Does this help?
C:\Windows\system32\Macromed\Flash\FlashInstall.log
=O====== M/10.1.53.64 2010-06-15+03-47-44.843 ========
0000 00000010 "C:\DOCUME~1\MONTYJ~1\LOCALS~1\Temp\FlashPlayerUpdate.exe"
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010 00000014 C:\WINDOWS\system32\Macromed\Flash\NPSWF32.dll
0011 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10h_Plugin.exe
0012 00000017 C:\WINDOWS\system32\Macromed\Flash
=X====== M/10.1.53.64 2010-06-15+03-47-59.125 ========
=O====== M/10.1.53.64 2010-08-18+05-49-18.281 ========
0000 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10h_Plugin.exe" -update plugin
0001 00000011 0
=X====== M/10.1.53.64 2010-08-18+05-50-34.859 ========
=O====== M/10.1.82.76 2010-08-18+05-50-35.015 ========
0000 00000010 "C:\DOCUME~1\MONTYJ~1\LOCALS~1\Temp\4.dir\InstallFlashPlayer.exe" -iv 0
=X====== M/10.1.82.76 2010-08-18+05-50-48.734 ========
=O====== M/10.1.53.64 2010-08-25+13-19-24.937 ========
0001 00000011 0
=X====== M/10.1.53.64 2010-08-25+13-19-46.171 ========
=O====== M/10.1.82.76 2010-08-25+13-19-46.218 ========
0000 00000010 "C:\DOCUME~1\MONTYJ~1\LOCALS~1\Temp\5.dir\InstallFlashPlayer.exe" -iv 0
0001
0002
0003
0004
0005
0006
0007
0008 00000014 C:\WINDOWS\system32\Macromed\Flash\NPSWF32.dll
0009 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10i_Plugin.exe
0010 00000017 C:\WINDOWS\system32\Macromed\Flash
=X====== M/10.1.82.76 2010-08-25+13-19-55.937 ========
=O====== M/10.1.82.76 2010-09-22+13-13-47.765 ========
0000 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10i_Plugin.exe" -update plugin
0001 00000011 0
=X====== M/10.1.82.76 2010-09-22+13-14-22.875 ========
=O====== M/10.1.85.3 2010-09-22+13-14-22.937 ========
0000 00000010 "C:\DOCUME~1\MONTYJ~1\LOCALS~1\Temp\6.dir\InstallFlashPlayer.exe" -iv 0
0001
0002
0003
0004
0005
0006
0007
0009 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10k_Plugin.exe
=X====== M/10.1.85.3 2010-09-22+13-15-54.437 ========
=O====== M/10.1.85.3 2010-11-11+05-04-38.156 ========
0000 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10k_Plugin.exe" -update plugin
0001 00000011 0
=X====== M/10.1.85.3 2010-11-11+05-05-37.000 ========
=O====== M/10.1.102.64 2010-11-11+05-05-37.125 ========
0001
0002
0003
0004
0005
0006
0007
0009 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10l_Plugin.exe
=X====== M/10.1.102.64 2010-11-11+05-05-54.359 ========
=O====== M/10.1.102.64 2011-02-12+06-09-54.218 ========
0000 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10l_Plugin.exe" -update plugin
0001 00000011 0
=X====== M/10.1.102.64 2011-02-12+06-10-49.250 ========
=O====== M/10.2.152.26 2011-02-12+06-10-49.437 ========
0001
0002
0003
0004
0005
0006
0007
0009 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10m_Plugin.exe
=X====== M/10.2.152.26 2011-02-12+06-11-18.859 ========
=O====== M/10.2.152.26 2011-03-05+23-15-12.656 ========
0000 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10m_Plugin.exe" -update plugin
0001 00000011 0
=X====== M/10.2.152.26 2011-03-05+23-16-16.843 ========
=O====== M/10.2.152.32 2011-03-05+23-16-16.875 ========
0001
0002
0003
0004
0005
0006
0007
0009 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10n_Plugin.exe
=X====== M/10.2.152.32 2011-03-05+23-16-32.406 ========
=O====== M/10.2.152.32 2011-03-27+05-20-46.218 ========
0000 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10n_Plugin.exe" -update plugin
=X====== M/10.2.152.32 2011-03-27+05-22-15.250 ========
=O====== M/10.2.152.32 2011-04-03+15-27-29.265 ========
0001 00000011 0
=X====== M/10.2.152.32 2011-04-03+15-35-26.265 ========
=O====== M/10.2.153.1 2011-04-03+15-35-26.359 ========
0001
0002
0003
0004
0005
0006
0007
0009 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10o_Plugin.exe
0011
=X====== M/10.2.153.1 2011-04-03+15-35-36.218 ========
=O====== M/10.2.153.1 2011-04-17+15-30-45.500 ========
0000 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10o_Plugin.exe" -update plugin
0001 00000011 0
=X====== M/10.2.153.1 2011-04-17+15-37-34.109 ========
=O====== M/10.2.159.1 2011-04-17+15-37-34.171 ========
0001
0002
0003
0004
0005
0006
0007
0009 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10p_Plugin.exe
=X====== M/10.2.159.1 2011-04-17+15-37-49.203 ========
=O====== M/10.2.159.1 2011-05-16+23-07-34.171 ========
0000 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10p_Plugin.exe" -update plugin
0001 00000011 0
=X====== M/10.2.159.1 2011-05-16+23-17-43.046 ========
=O====== M/10.3.181.14 2011-05-16+23-17-43.093 ========
0001
0002
0003
0004
0005
0006
0007
0009 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10q_Plugin.exe
0011 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
=X====== M/10.3.181.14 2011-05-16+23-17-52.375 ========
=O====== M/10.3.181.14 2011-06-07+23-47-56.437 ========
0000 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10q_Plugin.exe" -update plugin
0001 00000011 0
=X====== M/10.3.181.14 2011-06-07+23-49-30.781 ========
=O====== M/10.3.181.22 2011-06-07+23-49-30.843 ========
0001
0002
0003
0004
0005
0006
0007
0009 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10s_Plugin.exe
0012
=X====== M/10.3.181.22 2011-06-07+23-49-41.515 ========
=O====== M/10.3.181.22 2011-06-21+23-10-47.593 ========
0000 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10s_Plugin.exe" -update plugin
0001 00000011 0
=X====== M/10.3.181.22 2011-06-21+23-11-52.937 ========
=O====== M/10.3.181.26 2011-06-21+23-11-53.093 ========
0000 00000010 "C:\DOCUME~1\MONTYJ~1\LOCALS~1\Temp\7.dir\InstallFlashPlayer.exe" -iv 0
0001
0002
0003
0004
0005
0006
0007
0009 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10t_Plugin.exe
0012
=X====== M/10.3.181.26 2011-06-21+23-12-10.609 ========
=O====== M/10.3.181.26 2011-08-12+23-34-27.203 ========
0000 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10t_Plugin.exe" -update plugin
0001 00000011 0
=X====== M/10.3.181.26 2011-08-12+23-37-25.781 ========
=O====== M/10.3.183.5 2011-08-12+23-37-25.843 ========
0000 00000010 "C:\DOCUME~1\MONTYJ~1\LOCALS~1\Temp\8.dir\InstallFlashPlayer.exe" -iv 0
0001
0002
0003
0004
0005
0006
0007
0009 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10v_Plugin.exe
0012 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0013
=X====== M/10.3.183.5 2011-08-12+23-38-04.859 ========
=O====== M/10.3.183.5 2011-09-25+14-58-06.531 ========
0000 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10v_Plugin.exe" -update plugin
0001 00000011 0
=X====== M/10.3.183.5 2011-09-25+15-00-42.421 ========
=O====== M/10.3.183.10 2011-09-25+15-00-42.468 ========
0001
0002
0003
0004
0005
0006
0007
0009 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil10x_Plugin.exe
0013
=X====== M/10.3.183.10 2011-09-25+15-52-24.062 ========
=O====== M/10.3.183.10 2011-10-16+15-26-31.015 ========
0000 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil10x_Plugin.exe" -update plugin
0001 00000011 0
=X====== M/10.3.183.10 2011-10-16+15-27-09.359 ========
=O====== M/11.0.1.152 2011-10-16+15-27-09.484 ========
0001 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0002
0003
0004
0005
0006
0007
0008
0009 00000014 C:\WINDOWS\system32\Macromed\Flash\NPSWF32.dll
0010 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_Plugin.exe
0011 00000017 C:\WINDOWS\system32\Macromed\Flash
0012 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0013
=X====== M/11.0.1.152 2011-10-16+15-27-25.218 ========
=O====== M/11.1.102.55 2011-11-14+01-25-24.062 ========
0000 00000010 "C:\DOCUME~1\MONTYJ~1\LOCALS~1\Temp\5.dir\InstallFlashPlayer.exe" -iv 4
0002
0003
0004
0005
0006
0007
0008
0009
0011 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11e_Plugin.exe
0013 00000019 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0014
=X====== M/11.1.102.55 2011-11-14+01-25-34.109 ========
=O====== M/11.0.1.152 2011-11-14+01-19-29.296 ========
0000 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil11c_Plugin.exe" -update plugin
0001 00000011 0
=X====== M/11.0.1.152 2011-11-14+01-25-34.140 ========
=O====== M/11.1.102.62 2012-02-22+17-10-21.468 ========
0000 00000010 "C:\DOCUME~1\MONTYJ~1\LOCALS~1\Temp\6.dir\InstallFlashPlayer.exe" -iv 4
0002
0003
0004
0005
0006
0007
0008
0009
0011 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11f_Plugin.exe
0014
=X====== M/11.1.102.62 2012-02-22+17-10-32.265 ========
=O====== M/11.1.102.55 2012-02-22+17-09-09.484 ========
0000 00000010 "C:\WINDOWS\system32\Macromed\Flash\FlashUtil11e_Plugin.exe" -update plugin
0001 00000011 0
=X====== M/11.1.102.55 2012-02-22+17-10-32.296 ========
=O====== M/11.1.102.62 2012-03-18+00-12-06.820 ========
0000 00000010 C:\WINDOWS\system32\Macromed\Flash\FlashUtil11f_Plugin.exe -maintain plugin
=X====== M/11.1.102.62 2012-03-18+00-12-20.429 ========
=O====== M/11.1.102.62 2012-03-18+00-12-23.179 ========
=X====== M/11.1.102.62 2012-03-18+00-12-31.289 ========
=O====== M/11.1.102.62 2012-03-18+00-12-50.007 ========
=X====== M/11.1.102.62 2012-03-18+00-12-57.226 ========
=O====== M/11.1.102.62 2012-03-18+02-43-26.000 ========
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017 00000012
=X====== M/11.1.102.62 2012-03-18+02-43-34.187 ========
=O====== M/11.1.102.63 2012-03-18+04-22-42.703 ========
0000 00000010 "C:\Documents and Settings\Monty Johnson\My Documents\Incoming Files\uninstall_flash_player_32bit.exe" -force
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0017
0018
0019
0020
0021
0022
0023
0024
0025
0026
0027
0028
0029
0030
0031
0032
0033 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0034
0035
0036
0037
0038
0039
0040
=X====== M/11.1.102.63 2012-03-18+04-22-59.843 ========
=O====== M/11.1.102.63 2012-03-18+04-43-06.781 ========
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0020
0021
0022
0023
0024
0025
0026
0027
0028
0029
0030
0031
0032
0033
0034
0035
0036 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0037
0038
0039
0040
0041
0042
0043
=X====== M/11.1.102.63 2012-03-18+04-43-18.156 ========
=O====== M/11.1.102.63 2012-03-18+04-47-18.859 ========
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022
0023
0024
0025
0026
0027
0028
0029
0030
0031
0032
0033
0034
0035
0036
0037
0038
0039
0040
0041
0042
0043
0044
0045
0046
0047
0048
0049
0050
0051
0052
0053
0054
0055
0056
0057
0058
0059
0060
0061
0062
0063
0064
0065
0066
0067
0068
0069
0070
0071
0072
0073
0074
0075
0076
0077
0078
0079
0080
0081
0082
0083
0084
0085 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0086
0087
0088
0089
0090
0091
0092
0093
0094
0095
0096
0097
0098
0099
0100
0101
0102 00000020 C:\WINDOWS\system32\FlashPlayerCPLApp.cpl
0103
0104
0105
0106
0107
0108
0109
=X====== M/11.1.102.63 2012-03-18+04-47-42.000 ========
=O====== M/11.1.102.63 2012-03-18+05-33-52.578 ========
0000 00000010 "C:\Documents and Settings\Monty Johnson\Desktop\uninstall_flash_player_32bit(1).exe" -force
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022
0023
0024
0025
0026
0027
0028
0029
0030
0031
0032
0033
0034
0035
0036
0037
0038
0039
0040
=X====== M/11.1.102.63 2012-03-18+05-34-06.484 ========
=O====== M/11.1.102.63 2012-03-18+05-39-13.796 ========
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0020
0021
0022
0023
0024
0025
0026
0027
0028
0029
0030
0031
0032
0033
0034
0035
0037
0038
0039
0040
0041
0042
0043
=X====== M/11.1.102.63 2012-03-18+05-39-20.890 ========
=O====== M/11.1.102.63 2012-03-18+05-43-29.375 ========
=X====== M/11.1.102.63 2012-03-18+05-43-33.468 ========
=O====== M/11.1.102.63 2012-03-18+06-20-13.187 ========
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0020
0021
0022
0023
0024
0025
0026
0027
0028
0029
0030
0031
0032
0033
0034
0035
0037
0038
0039
0040
0041
0042
0043
=X====== M/11.1.102.63 2012-03-18+06-20-19.796 ========
=O====== M/11.1.102.63 2012-03-18+23-34-13.234 ========
0000 00000010 "C:\Documents and Settings\Monty Johnson\My Documents\Incoming Files\uninstall_flash_player_32bit(1).exe" -force
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022
0023
=X====== M/11.1.102.63 2012-03-18+23-34-22.078 ========
=O====== M/11.1.102.63 2012-03-19+07-26-14.140 ========
0000 00000010 "C:\Documents and Settings\Monty Johnson\My Documents\Incoming Files\uninstall_flash_player_32bit(2).exe" -force
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022
0023
=X====== M/11.1.102.63 2012-03-19+07-26-22.187 ========
Thank you for the FlashInstall.log file; I can see that there are many errors or warnings during the uninstall process. However, I cannot see any attempts to run the installers - could it be that the error occurs before it starts logging?
Two things to try:
Pat-
I tried the two things you suggested, no joy.
But, undaunted...I learned from your Fixit tool that I was missing two killbits activex updates, so I fixed.
Then...when checking my Java performance, (suggested elsewhere on da web), I learned I had SEVEN old Java versions that needed uninstalling. I didn't know this about Java!
So I deleted almost 900meg of old Java program.
Rebooted and loaded both new Flash (.exe and .msi) and...............................................................etc...................
YA-HOO IT'S A GO!
ps thank you thank you for all your help......
Thank you for the feedback; didn't know that Java could do such a thing...
Me either, and I still don't with any certainty. I did 2 different fixes at once. Uploading 2 "killbits actvex" updates in Windows, then uninstalling my 7 outdated Java files.
Which operation was the fix.....
But thanks again! Your suggestions gave me the inspiration to keep up the fight; not take hammer to cpu.
I found this little infonugget at MozillzZine.
The Flash uninstaller may not remove all Flash plugin files from all locations so you should search for and delete the following files, if found:
I'll try this next, if I can figger out how....
Isn't there an executable file that you can send to me? I am not computer savvy and I tried using the uninstall feature, and it worked, however when flash goes to open up, it stays stuck at 0% then becomes unresponsive, and I have to stop it .
What is your operating system, version & edition?
What is your web browser & version?
I have Microsoft XP and use Firefox
You can download the executable installer(s) from http://helpx.adobe.com/flash-player/kb/installation-problems-flash-player-windows.html#Install_in_a_...
I really appreciate you trying to help me. I downloaded the 32 bit version
and tried to open it and run it, but I received a box that only showed me an
error box with a red circle and an x through it, the ok button, and the
title of Adobe Flash Player Installer/Uninstaller on it.
I just tried it again and received an error msg that stated "Certificate
authentication failed, please re-install to correct the problem."
Which version of Firefox do you have installed?
11.0
11.0
OK, do the following please.
Should work.
Thank you so much for helping me. This worked, and now my husband won't be
upset with me. I really appreciate all of the help.
Michelle
