Hi all -- I have a couple thousand AI authored EPS files with a specific swatch name (SpotBlack) that I would like to rename (black) -- is there any method to do this en masse, preferrably outside of Illy using a text editor?
Thanks for your thoughts!
-g-
try with a couple of files first, before you run a gazillion of them.
var folder = Folder.selectDialog("Select Source Folder..."); // select folder
if (folder==null) {
alert("Good Bye");
else {
var files = folder.getFiles ("*.eps");
var fileCount = files.length;
if (fileCount>0) {
for (i=0; i<fileCount; i++) {
var idoc = app.open(files[i]);
try {
var iswatch = idoc.swatches["SpotBlack"];
iswatch.name = "black";
catch (e){}
idoc.close(SaveOptions.SAVECHANGES);
idoc = null;
else {
alert("There are no EPS files in this folder.");
Thanks CC -- I tried the script on a folder with a few EPS files, which didn't recognize the files -- so I edited the script to look for EPS files, but it still didn't work... I see you changed the script for the original (AI); did you make other edits, or just the two lines where EPS is indicated?
-g-
PS -- The whole reason I am in this pickle with SpotBlack vs black (vs the protected process color Black) is b/c AI won't let you name anything Black as as spot color (Black where the first letter is capitalized). So I created a spot called SpotBlack and have been using that for 2+ years. However, the rip I use isn't smart enough to realize that SpotBlack = Black, so I have to manually assign it to a specific ink. It wasn't until recently did I realize that I can assign a spot color in AI called 'black' (lowercase 'b') that doesn't upset its sensibilities and works in the rip. So now I have a few (thousands!) files where SpotBlack is indicated. Hence my plea. Back to the point: sometimes when I rename spot colors, even when using the l/c 'b' AI throws up an alert re: protected process color names -- so, I don't know if this is happening here, but it might.
Cheers!
-g-
>.. preferrably outside of Illy using a text editor?
If (a) you are on a Mac and (b) you are SURE all of these EPSes contain pure EPS text (*no* binary information *at all*) -- then you could take look at TextWrangler. It's a straight-on plain text editor (hence, no binary data embedded in your files please) for the Mac (hence, uh, the "Mac required") and it has the option of doing find-and-replaces on a selection of files.
As with Carlos' script: make sure you have a copy of the entire set of files before you let it rip through them.
I have to confess I kind of cheated, I wrote the script and tested it with AI files, and it was after I posted that I realized you needed eps, then I just assumed it would work and just edited my post to read eps, without testing.
anyway, I just tested with eps I created and it works as expected.
can you share a couple of samples so we can have a look and try to find out why is not working on your end?.
