CQ5
Anzy_cq55
Not able to debug in CQ5.5
Mar 26, 2012 11:36 PM
I am running the cq jar in debug mode (-Xdebug -Xrunjdwp:transport=dt_socket,server=y,suspend=y,address=30303 -Xnoagent -Djava.compiler=NONE)
I am using Eclipse/IntiellJ ide. The connection is established but the debugger doesn't work.
Response will be appreciated.
    Mar 27, 2012 12:04 AM   in reply to Anzy_cq55
    where are you setting a break point? in a JSP? for that please add a JSR-45 remote debug configuration in your IDE (e.g. IntelliJ). use the following debug options:
    -Xdebug -Xnoagent -Djava.compiler=NONE -Xrunjdwp:transport=dt_socket,server=y,suspend=n,address=30303
    Mar 27, 2012 12:33 AM   in reply to Anzy_cq55
    how are you starting CQ? it is possible that quickstart forks the JVM, so that you're not debugging the right java process. i'd recommend to start with -nofork option for debugging.
    Mar 27, 2012 4:49 AM   in reply to Anzy_cq55
    as i said, your JVM is being forced due to low memory settings. start like this:
    java -Xdebug -Xnoagent -Djava.compiler=NONE -Xrunjdwp:transport=dt_socket,server=y,suspend=n,address=30303 -XX:+HeapDumpOnOutOfMemoryError -XX:MaxPermSize=256M -Xmx1024m -Dorg.apache.sling.commons.log.level=INFO -jar cq-author-4502.jar -p 4502 -verbose -nofork
    Jun 16, 2012 8:53 PM   in reply to hypnotec
    Greet! It work! thank you hypnotec!
