I have a XML feed from a web app (over which I have control as to how the XML is tagged etc) and the XML drops into an indd template, applies character, para, table and cell styles.
The issue I have is that if an XML tag is empty (and they often are), I can't search and replace for extra carriage returns as there's markers in there from the XML (I believe, correct me if I'm wrong).
If I select the invisible characters and paste them into the Find and Replace dialogue box, they show up as ~I (GREP) or ^I (normal), which is apparently an index marker.
Is there any way of getting rid of these via a script? If I try to search for those invisible characters, no changes get made, i.e. none are found.
Is there a GREP method that may work?
Thanks in advance.
It is already discussed few months ago.See the thread http://forums.adobe.com/message/4139703#4139703, Any way I'm reposting it. Use the below script,
var xpath ="//*";
var root = app.activeDocument.xmlElements[0];
var node = null;
try {
var proc = app.xmlRuleProcessors.add([xpath]);
var match = proc.startProcessingRuleSet(root);
while(match!=undefined) {
node = match.element;
match = proc.findNextMatch();
content=node.contents;
if(node)
app.select(node);
var myText = app.selection[0];
var content=myText.contents;
if(content.search(/^[\s\r\n]+$/)!=-1){
myText.untag();
}//End of While
} //End of Try
catch(ex){
alert(ex);
finally {
proc.endProcessingRuleSet();
proc.remove();
Green4ever
Thanks very much for that. I did search this forum and not sure why I didn't see that earlier post.
The variable xpath - what does that refer to, i.e. what should I set that to? Is that the path to the XML file, or the active document?
Sorry for the newb questions - this is somewhat of new territory for me.
Simon.
You can use the script as is. The variable xpath holds a xpath expression. "//*" will match any tag in any location. To know more about xpath see http://www.w3.org/TR/xpath/#section-Introduction and you can see some examples here: http://www.adp-gmbh.ch/xml/xpath.html. Remember that this is not a recomendation, it is just for reference only.
Green4ever
