Brijesh Gupta sapple
Flash media server 4.5 log files filed x-duration value always 0
Mar 27, 2012 2:55 AM
Tags: #flash #server #client #connection #has #time #media #the #been #seconds #x-duration #connected
Hi guys,
When i read flash media stats log file then i found x-duration value 0 only in case for x-event unplublish this filed have a value.
My question is x-duration filed value is the number of seconds the client has been connected. then why i am getting 0 in case of publish and publish-continue only get the value in case of unpublish.
Any one explain ? how can i get the connection time in case of publish and un publish
Brijesh
    Apr 16, 2012 7:32 AM   in reply to Brijesh Gupta sapple
    For a stream the x-duration is the number of seconds the stream has played. Hence at publish and record events this value is 0 and is non-zero for unpublish event.
    In case of session, this field contains the number of seconds the client has been connected. This will be 0 for connect event and non-zero for disconnect event.
    The time an event occurred is reflected under the time filed in access log.
    Apurva
