My company has nearly all adobe applications installed from PageMaker 6.5 through InDesign 5.5. We use them all frequently. I'm trying to set my defaults on the Mac Pros and it is not working.
Specs if Needed:
OSX 10.6.8
Model Identifier: MacPro5,1
Processor Name: Quad-Core Intel Xeon
Processor Speed: 2.8 GHz
Number Of Processors: 1
Total Number Of Cores: 4
Memory: 6 GB
Boot ROM Version: MP51.007F.B01
+BootCamp dual boot Windows 7
We proof out all files in the version that it comes to us. Our customers are on different versions than the most current, and it's driving us crazy that we can't set the defaults for
each Adobe application. For Instance,
We want for Defaults:
Photoshop = CS4
InDesign = CS4
Illustrator = CS5
etc.
The Finder will not allow us to make the change to open all of a certain file type in the version we want by default. We also use a third party application that allows us to "double
click" InDesign files and open them in the correct version. This saves valuable navigation time and because of the OS's problem with using the correct icons, it also saves us time
dealing with the "Untitled" document when we accidentally convert by opening in the wrong application by mistake. We have gone through Onyx utilities and massive permissions
troubleshooting to no avail. Does anyone know how to set the default for ALL files of a type for Adobe Apps? This has been thoroughly tested and is not working on 10 plus
machines, and only effects Adobe apps.
Any Ideas?
Yes, Soxy works on a Mac. Here's the link. Check it out:
http://www.rorohiko.com/wordpress/downloads/lightning-brain-soxy/
I think you miss understand the question. There is a problem with OSX 10.6 and Adobe Apps. 10.5 ok, not sure about 10.7 because of all of the other Adobe problems we downgraded the test machine that we used for the upgrade. There is no way that I have found to make the files “Double-Clickable” through assigning a default application of files with Adobe extensions. We already have an app. that we use and it worked fine until 10.6. I can’t just approve a division-wide purchase of software for a bug that may be solvable by other means (by the way supposed cost of the licensing Soxy is deceiving at $20. Not for us. For companies it’s $20 per platform & also for each time Adobe updates. When we swap out hardware, we have to pay $40 again Re: How to set my default application...not working. Their pricing is absurd). $40 x a couple hundred machines every 18 months or so, uugh! The ten or so I’m working with are just the ones in my immediate department.
I know you have good intentions with your reply and I appreciate it, however I’m looking to solve the problem, not put a band-aid on it. If the problem is by design so Rorohiko can hold companies hostage, then I guess we’ll just have to deal with the few extra clicks it takes to figure out which version we’re in need of, and dragging to the launch bar.
Thanks very much for your reply,
Seth
