Windows 7 Ultimate with SP1 64 bit
Adobe Acrobat 10.1.2
When I try to print a webpage in IE or Firefox to PDF format, I get a Window indicated in the subject header. The details are:
Problem signature:
Problem Event Name: BEX64
Application Name: splwow64.exe
Application Version: 6.1.7601.17514
Application Timestamp: 4ce7b4c8
Fault Module Name: ADUIGP.DLL
Fault Module Version: 10.1.0.519
Fault Module Timestamp: 4db4cdbb
Exception Offset: 000000000000efb4
Exception Code: c0000417
Exception Data: 0000000000000000
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional Information 1: 3788
Additional Information 2: 3788f53ec30c6f4a2a67fcde28b876c9
Additional Information 3: e23c
Additional Information 4: e23cf34f9ee45a6fe33cc06effe64070
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Any ideas? This started happening a few days ago. Nothing has changed.
This problem is much worse than it appears at first glimpse!
1. It also occurs on my Win7 x64, no SP1, under Acrobat 9, ADUIGP.DLL, version 9.2.0.112. For example when PDF printing from a browser. So it appears be deeper in the code and not specific to Acrobat 9/10 or Win 7 SP1 or no SP1.
2. As Adobe is patching sometimes it is getting better, sometimes worse, on and off for about a year. This round is is really horrible. I am certain more people have the same issue. The application (browser) I use, can do print 1-2 times, then printing locks.
2. Workaround: Kill splwow64.exe (32bit to 64 bit print mapping), restart printer spooler service, restart application, print 1-2 times, repeat.
Adobe: Please fix this or at least provide an open/honest explanation what is going on.
Anyone else: If you have the same issue, please post here so it becomes more obvious that there is an issue.
Thanks.
Kindly refer to mentioned link for print related crash in 10.1.2 - http://kb2.adobe.com/cps/928/cpsid_92870.html
I am curious if this is the issue that solves the problem for ccslai in Acrobat Reader 10. It certainly is not an issue with double sided printing being accidentally set for me with Acrobat 9 and PDF printing. It behaves more like a thread locking up. If you check around, it clearly is a popular problem: "windows 7 Acrobat splwow64" has over 10k hits for problems on Google, mosty from 2011. It could be an issue between 32bit and 64bit, since it appears to clear up issues for Office going to 64bit versions. ...
Your suggestion works fine. But obviously not somethign I wanna do everytime. So I've been using cutepdf writer to print to pdf ever since I posted my issue.
Just wish Adobe tech support would read out grief and look into our problem more closely.
Hello Vamalik,
1. Yes I have tried to repair Acrobat 9. It does not help. I am on the latest patch level for the extended version.
2. The issue is obviously not confined to Acrobat 10 (9 has it too).
3. If you would like my 2 cents: It is somewhere in the thread processing between Adobes Print drivers and the splwow64. I would run the Appliations( it is plural unfortunately) where this shows up in debug mode and try to catch the error thrown by the listed modules, e.g., ADUIGP.DLL.
With various patches recently deployed by Adobe, the gravity of the situation varies. Apparently this is a widespread issue reaching far further than this little discussion. It clearly does not affect all applications, e.g., several Microsoft apps with other printer drivers work just fine. However, there is one guarantee: As long as the quality of the software keeps degrading like this, there is no reason to build trust in online services or new "features". Clearly there is some homework to be done. No reinstallation or "repair" fixes it. Thanks.
So here I have a product that I've WASTED $450 or whatever money on it because:
1. The product is not working as it should
2. Adobe support reads people's grief and doesn't give a damn or even attempt to look into it, thinking that the issue will go away on its own
Seriously, why does Adobe even have a SUPPORT FORUM?
In response to vamalik, 9. Feb 29, 2012 5:22 AM:
1. Are you seriously asking me if the problem started with just version 10.1.2 or if I am experiencing ithis with any earlier version also?
Note:
a) My first reply clearly stated that I am experiencing the problem with Win7 x64, no SP1, under Acrobat 9, ADUIGP.DLL, version 9.2.0.112. is that version 10.1.2 or earlier????????? (2. Feb 7, 2012 5:02 PM (in response to ccslai))
b) ... It certainly is not an issue with double sided printing being accidentally set for me with Acrobat 9 and PDF printing ... If you check around, it clearly is a popular problem: "windows 7 Acrobat splwow64" has over 10k hits for problems on Google, mosty from 2011....
Is that version 10.1.2 or earlier??????? (4. Feb 8, 2012 4:30 AM (in response to vamalik))
c) ... 2. The issue is obviously not confined to Acrobat 10 (9 has it too).... Is that version 10.1.2 or earlier??????? (7. Feb 13, 2012 6:06 AM (in response to vamalik))
Let me clearly also state my frustration:
a) I had purchase the extended Acrobat version, and will lose features going to 10. Adobe does not honor if I have more than 2 products to upgrade to a suite, so I won't. I am with cclai's complaint about the stability of the software getting worse than it used to be.
b) I clearly provided a technically applicable and viable shor term patch for the problem
c) I would like to officially apply for consulting and obtain compensation if I need to explain in 3+ answers (on a single page) to an employee, i.e., how to read customer emails and technically correctly interpret them.
Thanks.
We have also been experiencing this ever since upgrading to Windows 7 SP1 x64 and AdobeCS5.5 and Acrobat 10x all version thru 10.2.1. We have made the recommended change to the time in which splwow64 process times out but to no eval. After printing 2-3 PDF's to a Xerox printer with the latest driver attached to a network print server running Windows 2008 R2 we get this;
Print driver host for 32bit applications has stopped working.
Problem signature:
Problem Event Name: APPCRASH
Fault Module Name: x2utilGT.dll
Fault Module Version: 5196.1000.0.0
Fault Module Timestamp: 4d5d4238
Exception Code: c0000005
Exception Offset: 0000000000037e81
OS Version: 6.1.7601.2.1.0.256.4
Locale ID: 1033
Additional Information 1: 91f6
Additional Information 2: 91f61deda7d90b22e28c0c1d68e1c844
Additional Information 3: a5a7
Additional Information 4: a5a772e1c83123e50d12b16dfc1e5403
The only work around is to kill the process splwow64.exe if running close the PDF then uninstall and reinstall the printer open the PDF and then you can print. I have an office full of very unhappy users who print form PDF to these printer often. I hate to answer I know it's a known problem but Adobe or MS evidently does not want to own it and actually fix it. With the money we spend on these applications and maintenance it is nothing less than distgusting!
Dear User,
I would request you to try printing using any other third party application like Notepad/Word. If you are still getting this error then this can be an issue either with printer driver or Microsoft.
Kindly refer to the links below to confirm:
http://forums.techarena.in/operating-systems/1357469.htm
Dear sonal2890:
could you please help to clarify:
"I would request you to try printing using any other third party application like Notepad/Word. If you are still getting this error then this can be an issue either with printer driver or Microsoft."
- The issue is in my case specific to pdf print. It has nothing to do with using MS Word, notepad or similar. Notepad or word print just fine by themselves.
- Did you read the previous posts in this thread?
- Have you attempted to reproduce the problem?
- Are you suggesting to avoid using Adobe products to avoid the problem?
The issue is IMHO most likely not caused solely by MS but by the Adobe PDF printer driver interacting with splwow64. There could be an issue with Adobe's 64/32 bit handling involved. The code/paradigm could be one shared across various Adobe versions. Question: Is there any code shared between Acrobat 9 and 10 or are they completely distinct?
Thank you for your help.
No, I am not implying that.
Did you read the thread above? It implies multiple Acrobat versions showing the same issue.
Even if I would eventually do so, I would do it because Adobe has taken away functionality from my Acrobat 9 Extended version in Acrobat 10 (without compensation). At this time I am stuck with Acrobat 9.
Sorry, this is really frustrating. Let me note in the most polite way and with all due respect that
- The replies are not demonstrating an approach leading to a solution. They mostly are questions that imply user error, point at other companies.
- Questions back at Adobe:
A simple Google search on "Adobe splwow64 error" shows 10200 hits. This hardly appears to be a coincidence or a problem isolated to this thread. There is certainly other material related to the same issue pointed to here.
Are you attempting to answer any of the questions posed in this thread?
Are you attempting to replicate the problem as a first step to a solution? How are you doing so?
Thank you again for your help.
To be very clear, this is absolutely not an Adobe Support forum. It is a User-to-User forum for individual users of Adobe products to mutually assist each other. that is not officially monitored by Adobe and is not an official function of Adobe Technical Support. If you want to communicate with Adobe Technical Support, please contact them directly.
- Dov
Hello Dov,
thanks for your time, point well taken.
However from experience in a several decade long career in computer related engagements, and again with all due respect:
- This is a user forum for mutual support.
- Adobe offers paid support for issues with their software. Typically that requires today well replicatable bugs and issues so they can be fixed in an expedited, well tracked fashion.
- A mutual user support forum is a part of the company's eco-system that may permit to pick up other emerging concerns and issues with a product, to discover new desired features, etc. It therefore offers a window of opportunity to discover emerging things that may not be well replicated yet.
- For employees of the company it is also an opportunity to build confidence in the company support so users trust paid support to solve problems quickly.
- In this context and the problem here may not be well reproduced yet, but appears to have a broader impact. Who at Adobe would be most interested in solving it?
- To ponder as related: how did the notion about bugs in Flash software affect Adobe's reputation? Were they quickly solved by paid support? Was the problem addressed proactively?
For the record: I find myself often enough in situations defending Acrobat/PDF, so I certainly only wish the Adobe products to be the best they can be.
Thank you again for your help and for participating in this forum.
How can a user assist other users when it seems that the issue is specific to the Adobe product??? What is the user supposed to do??? Offer a TEMPORARY fix? Isn't it Adobe responsibility to come up with a PERMANENT solution and post the solution somewhere (either here or in a KB or get a patch out or something)??? As someone has stated, googling has come up with tonnes of other users experiencing similar issue. Either Adobe doesn't understand or this company doesn't give a crap.
If this forum board isn't monitored by Adobe, why have it?
If I call Adobe Tech Support up and I pay for the support, will they actually get this issue fixed or will they just keep the ticket open and hope that they won't hear from me again?
Going on Trend Micro or Dell or Computer Associates forum boards, the tech support people there have bee nothing but good people when it comes to offering solution. Adobe Support forum, on the other hand, has been way in the dumps.
The company I work for has 500+ copies of Acrobat and we are definitely not going Adobe again in the future...
I have also had problems with this. It definitely appears to be a 64bit 32 bit conflict. I'm using Windows7 64 bit. Adobe Acrobat 9 and Office 2010. Here is typically what happens. I am in the habit of saving all my important emails as PDFs. First I copy a filename out of the email. The I select print and paste this filename into the dialogue box. At this point Outlook will lock up and the warning message pops up saying "the 32 bit print host driver has stopped working." It appears like the paste function cannot convert the contents of the clipboard to unformatted text while the print host driver is open. Some PDF printers that are fully and truly 64 bit do not have this problem. However their functionality is mediocre at best.
Here's my work around. I downloaded "Pure Text" from www.stevemiller.com With this application running, I simply hit Cntrl+V after copying and prior to pasting. Fixes my problem but it's an extra move evry time I save an email.
Couple of questions:
1. Are you facing this problem in converting every site or with some sites it is working fine also?
2. I have faced this either with some specific sites or when i am printing sites to PDF in parallel (i.e. printing 2nd site even when first one is not over). Can you share some of your sites which you printed to PDF?
Thanks.
Has anybody had this resolved...?
We are using Windows 7 Pro and Adobe Acrobat 9
We are getting the error:
It only happens with PDF's send in from other peaple which are created using Xerox Workcentre or Canon iR-ADV C7065.
All other PDF printing and Word printing etc works fine.
The same PDF's print fine on an XP machine with the same Adobe Acrobat 9 software
You can try to work around this by:
1. Killing the splwow64.exe and restarting the spoolsv.exe service.
2. The only printing that has issues with the dirver is Adobe's.
3. No, updating to the latest printer drivers does not help, it is Adobe's PDF driver and updated together with other Acrobat updates. I am not holding my breath that Adobe will ever address it.
