*r0d*
Is there a way to secure a PDF properly?
Mar 20, 2012 5:28 AM
Tags: #acrobat #permissions #security #password #fail
Hi, I have been producing quite a few .PDF's recently and I'm looking for an effective way to disable/allow permissions such as printing, extracting, screen grabbing (not sure if this is possible).
In less than 5 minutes I can download security removal software, remove the password and send the file to the printer
I was just wondering if there is anything I can do to avoid someone from doing this? Is it actually possible to make a PDF secure?
  • George Johnson
    Aug 11, 2002
    Mar 20, 2012 9:17 AM   in reply to *r0d*
    You will have to use a DRM-based approach, such as Adobe's Rights Management Server: http://www.adobe.com/products/livecycle/rightsmanagement/
  • George Johnson
    Aug 11, 2002
    Mar 20, 2012 12:25 PM   in reply to *r0d*
    That's the idea. The type of sotware you're referring to won't remove such security. The downside is the expense, but there are many cases where it's reasonable. It is a different security method that supports, and is totally different than standard password security.
    Mar 27, 2012 10:08 AM   in reply to *r0d*
    You can encrypt files for specific individuals using their public key and Signature-Based security. That just won't work for the general audience.
    The thing is, this isn't just a problem with Acrobat. ANY password based security that allows for infinite tries can be broken on any file of any type. It's just math folks. The only way to "properly" secure a digital file is to separate the file and the encryption/decryption keys so that they don't travel together. That involves either a token or some for of network infrastructure or both. You just can't do it on the cheap.
    That said. Take a look at FileOpen.com - they have some very affordable options.
    J-
