This is all about the "file is not a valid mpeg" error.
I'm using Encore 5 to author a DVD, with elements produced in Premiere 4, After Effects 4 and Soundbooth 5.
Video has gone through Media Encoder 4 and audio through Media Encoder 5.
Video is m2v and audio is ac3. There are not other formats.
Check Project gives no errors on anything.
When it comes to authoring the DVD, 4.67 gb have been used leaving 24MB free disc space.
The first few times I tried to author the DVD, after initially reporting no errors, it then wouldn't burn a disc because it said one of the timelines used audio files of different formats. It didn't, but I put them through Media Encoder again anyway, which seemd to solve that problem, but who knows.
(In the DVD Transcode Status, in the Project window, most ac3 files say Don't Transcode, but the three smallest - less than 1MB - say Transcoded [then Automatic in DVD Transcoding Settings]. Don't know why it does that or if that has anything to do with the authoring problem.)
Anyway, now, every time I click Build, it works for a while but then gives "file is not a valid mpeg" error and stops. Doesn't say which file. ALL the files are mpegII.
It will take me days to re-render all the files. Is there any way to find out which is the problem file - it doesn't do anything useful like tell you - or any reason why it isn't recognizing an m2v file which I can do something about, please?
This is driving me crazy. Any advice will be much appreciated.
Thanks in advance,
Steve
Hi Bill,
Thanks for the reply.
Across the DVD, I'm using between 5.5 and 6.5. All CBR.
I've just had a thought - can I mix videos with different bitrates on the same timeline? I've got an intro at 6.5 followed by a 60 min video at 5.8. Could that be the problem? Does all the video on a particular timeline have to be the same bitrate?
If not... any ideas, please?
Thanks again,
Steve
I have never mixed different Bit-Rate materials, on the same Timeline, and especially as I usually do one Timeline for each Video Asset (edited to be a "scene," or Chapter). I cannot tell you.
What happens if you create one Timeline for one Asset, and then another for the remaining one?
Does that change anything?
I had been thinking that you had an MPEG that was out of the DVD-spec., but that usually results in Encore needing to Transcode again, to bring the file into spec.
Good luck, and I wish that I knew more about mixing Assets with differing Bit-Rates.
Hunt
Hi Bill,
I was thinking about trying two timelines and using a playlist to run them together to see if that would resolve the issue. The problem is that Encore doesn't say which file or timeline is causing the problem, so I'm just guessing that this could be the issue.
That doesn't answer the problem of why Encore also thought that two audio tracks were different formats when they weren't, which is a problem in case that error crops up again.
Anyway, I'll try two timelines and re-render the intro to the same bitrate to see if either works.
Thanks, Bill.
Steve
That was your mistake. Premiere Pro, AME and Encore all use an indexing system for compressed files. You can't change anything about those files without also changing the indexing, or you will get this error.
The solution is to never change a file once it's imported into Encore. If you change an asset in any way, even reencoding, then you have to rename that file, which forces Encore to do redo the indexing.
