Question about serial number on photoshop elements 10.
Guest
Mar 27, 2012 Mar 27, 2012
Hi I just installed photoshop elements 10 on my laptop using disc 2 for the 64 bit connection but I figured out I only have 32 bit connection. How do I safely remove photoshop and then load again using disc 1 for 32 bit connection. After I installed from disc two I was not prompted for further discs and an error box popped up regarding istallation; however, the photoshop icon is on my desktop and will lauch when I click it. My concern is if I remove photoshop from disc 2 to install from disc 1 when I have a problem with the fact that i already put the serial number in. I wasn't prompted to create a adobe account during installation. Any suggestions/help would be appreciated. Thanks
2.1K
Guest
I meant to write "will I have a problem with the fact that I already put the serial number in during the first installation'
1) First, if you have 32 bit operating system only then you will not be able to install elements using disc 2 , it would have prompted the error message at the time of installation only.
2) If you still want , you can uninstall the photoshop and then install the elements from disc 1 without any issue.
Adobe Employee ,
If you have purchased only Photoshop Elements 10 then the second disc is the trial of Premiere Elements 10.
