Hello,
Tutorial says:
Create a new folder named AudioStreams at C:\Program Files\Adobe\Flash Media Server 4.5\applications.
Open the AudioStreams folder and add a new folder named streams.
Inside this folder place a new folder named _definst_ and copy the four audio files in the Exercise to the _definst_ folder.
I am confused when should we create definst folder and when C:\Program Files\Adobe\Flash Media Server 4.5\applications\live\media folder?
thanks.
Let me explain you - first of all "live" does not have "media" folder my default - only "VOD" application. "media" folder is nothing but VirtualDirectory setting done at Application.xml level to tell FMS so pick the media files from "media" folder.
By default if you are creating your own simple application - you need to create "streams/_definst_" as its default path where streams would get created or looked for - when you are connecting to "_definst_" or when you dont specify any instance name
...Copy link to clipboard
This would be helpful to you for more details about this:
http://www.adobe.com/devnet/flashmediaserver/articles/beginning-fms45-pt02.html
Hello Bharat,
Thanks for the reply.
I have indeed read this article and got confused reading this
Can you pls clarify in one liners when we should be accessing media folder and when streams\definst??
thanks.
By default if you are creating your own simple application - you need to create "streams/_definst_" as its default path where streams would get created or looked for - when you are connecting to "_definst_" or when you dont specify any instance name in your connection URI.
You use "media" or for that matter any folder - if you have preconfigured VirtualDirectory for your application.
Thank you.
Understood this now.
