Question about serial number on photoshop elements 10.
Mar 27, 2012 12:05 PM
Hi I just installed photoshop elements 10 on my laptop using disc 2 for the 64 bit connection but I figured out I only have 32 bit connection. How do I safely remove photoshop and then load again using disc 1 for 32 bit connection. After I installed from disc two I was not prompted for further discs and an error box popped up regarding istallation; however, the photoshop icon is on my desktop and will lauch when I click it. My concern is if I remove photoshop from disc 2 to install from disc 1 when I have a problem with the fact that i already put the serial number in. I wasn't prompted to create a adobe account during installation. Any suggestions/help would be appreciated. Thanks
    Mar 27, 2012 1:08 PM   in reply to jlh2012
    1) First, if you have 32 bit operating system only then you will not be able to install elements using disc 2 , it would have prompted the error message at the time of installation only.
    2) If you still want , you can uninstall the photoshop and then install the elements from disc 1 without any issue.
    Mar 27, 2012 2:50 PM   in reply to Manish-Sharma
    If you have purchased only Photoshop Elements 10 then the second disc is the trial of Premiere Elements 10.
