This question was posted in response to the following article: http://help.adobe.com/en_US/Presenter/7.0/WS8815BC0A-5D22-4f29-87B9-D9047B5B57E4.html
I have Adobe Presenter 7.0.5, in which with recently updating to 7.0.7 version.
Is there any workaround to correct that error?
Many thanks in advance for any feedback from the adobe support team or from any other colleagues that are using Adobe Presenter (;-)).
If you want to change SWF loading text then please use 7.0.6. In Adobe Presenter 7.0.7 this will not work due to a known issue.
Is there any way to change the SWF loading page in Adobe Presenter 7.0.7? Its quite frustrating that all updates I needed are in 7.0.7 but I have to revert back to 7.0.6 just to fix the SWF loading page. Any thoughts?
I would also love to have an answer for this. It's completely unprofessional to be forced to have all your courses branded with "Adobe Presenter". I'm working on a very large project, and I'm stuck on this one little snag.
Any advice, fixes, or workarounds are welcome!
Hi David,
Which Presenter version are you using ?
Alpi Agarwal
Adobe Presenter Engineering Team
I'm using Presenter 7.0.7, which is the AS3 - based version. I've tried the workaround for AS2, which involves editing the data/vconfig file, but I get the save result as the OP.
I was actually able to manipulate the load text by using a Beta version of SWFInvestigator. I went into the Hex Editing tab, and found the lines that contained the actionscript for "Adobe Presenter" I saved it back out as a ZLIB compressed .swf, and it worked.
Is there a better / easier way, though?
