donnaoverall
InDesign CS5 for Mac crashes on opening file. Have replaced References and all other suggestions.
Mar 28, 2012 1:20 AM
Tags: #cs5 #indesign_cs5_files_not_opening #cs5_crash
I am having a problem with InDesign CS5 crashing when I try to open a file that formerly opened just fine. Even restored versions from Time Machine or that I had a backup saved on an external hard drive will not open. I recently had to reconstruct a 90 page magazine for the same reason. I heard that Extensis Suitcase might be causing the problem so I disabled the plug-in, but still can't get the file open. The file in question is full of tables and would be a nightmare to redo. I am running Snow Leopard. It will open briefly and tell me that fonts are missing, then crash.
This is the first part of the crash report:
Process:         Adobe InDesign CS5 [3618]
Path:            /Applications/Adobe InDesign CS5/Adobe InDesign CS5.app/Contents/MacOS/Adobe InDesign CS5
Identifier:      com.adobe.InDesign
Version:         7.0.0.355 (7000)
Code Type:       X86 (Native)
Parent Process:  launchd [243]
Date/Time:       2012-03-28 04:09:54.429 -0400
OS Version:      Mac OS X 10.6.8 (10K549)
Report Version:  6
Interval Since Last Report:          726303 sec
Crashes Since Last Report:           21
Per-App Interval Since Last Report:  644196 sec
Per-App Crashes Since Last Report:   20
Anonymous UUID:                      3E14D8F3-3E05-4DD3-AF05-C27CC15C3CA3
Exception Type:  EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Crashed Thread:  0  Dispatch queue: com.apple.main-thread
    Mar 28, 2012 2:18 AM   in reply to donnaoverall
    You stopped just before the part of the report that is useful. Please post the entire report on Pastebin.com (NOT here), the put a link to it here.
    Mar 28, 2012 3:06 AM   in reply to donnaoverall
    Do you have some sort of plugin from MindStream? Looks to me (but I'm not an expert) like that's the problem.  Also, you need to update to 7.0.4...
    Mar 28, 2012 4:30 AM   in reply to donnaoverall
    Your crash logs say 7.0.0.355. Use Help > Updates... and if that doesn't work, try downloading and running the updater from the Adobe.com updates page.
    Mar 28, 2012 4:38 AM   in reply to donnaoverall
    To diagnose the hang, we need two pieces of information, an activity monitor report and a crash report from a forced crash. See http://forums.adobe.com/message/4199358#4199358 for how to do that.
    Mar 28, 2012 7:06 AM   in reply to donnaoverall
    I believe you have Extensis font management installed on your computer?
    Which might be causing the problem......
    Apr 1, 2012 11:49 PM   in reply to donnaoverall
    As a tip for corrupt .indd files that can not be opened after trouble-shooting, we, Markzware, offer a InDesign File Recovery Service. See:
    http://markzware.com/support/faq/recover-bad-file-service/
