I have a form where I fill a customer-no. into an input field and get the customer name using databinding.
This works fine, but when I put non-numeric values into customer-no I get following error:
Error invoking CFC customer.cfc : The CUST_ID argument passed to the getcustomer function is not of type numeric. [Enable debugging by adding 'cfdebug' to your URL parameters to see more information]
The message is correct, but how can I avoid to run the getcustomer function when the value is not numeric?
Here is my code:
The form:
<cfinput type="text" name="customer_no" style="width:140;background-color:yellow" maxlength="10" validate="integer" validateat="onblur" message="Customer No. format is integer">
<cfinput type="text" name="customer_name" style="width:170" maxlength="200" bind="cfc:customer.getcustomer({customer_no})" readonly="yes">
customer.cfc:
<cfcomponent >
<cffunction name="getcustomer" access="remote" returntype="string" output="yes" >
<cfargument name="cust_id" type="numeric" required="true" >
<cfset r_customer = "">
<cfquery name = "select_customer" dataSource = "x">
SELECT name
FROM customer
WHERE id = <cfqueryparam cfsqltype="cf_sql_numeric" value="#arguments.cust_id#" >
</cfquery>
<cfreturn r_customer>
</cffunction>
</cfcomponent>
Change the argument to type="any", then use isNumeric() inside your function. If it's not numeric, return an empty string.
Yes it works. Thank you very much!
Sometimes the simplest solutions are the best
That is a trick question! The attribute bind="cfc:customer.getcustomer({customer_no})" implies that the function will run automatically, whether or not customer_no is numeric.
