[JS][CS4] - populating a drop down with list of printers?
Mar 27, 2012 9:04 AM
Tags: #illustrator #printer #javacsript #printerlist
Hello,
I'm trying to populate a drop down field with the list of available printers. Here's what I have:
var printerList = app.printerList;
var w = new Window ("dialog");
w.orientation = 'row';
var dropDown = w.add("statictext", undefined, "Please select the printer");
var dropDown = w.add ("dropdownlist", undefined, printerList);
dropDown.selection = 0;
var buttonGroup = w.add ("group");
buttonGroup.add ("button", undefined, "OK");
w.center();
w.show();
This will populate a drop down with "Printer, Printer, Printer, Printer" for each printer instead of the name of the printer (which is what I want).
When I try:
var printerList = app.printerList.name;
I get a drop down of blank entries.
Any ideas on what I'm doing wrong?  How exactly does the printerList work?
Lindsay
    Mar 27, 2012 9:53 AM   in reply to booyajamo
    When I run the script that you have in the box above I get
    Is this not what you get? Try commenting out the first var setting the printerList and target illustrator like this
    #target illustrator
    //var printerList = app.printerList.Printer.name;
    w.center();
    w.show();
    Mar 27, 2012 5:25 PM   in reply to booyajamo
    What OS? It appears a PC; I'm on a Mac. Maybe that's the difference.
    Mar 28, 2012 8:28 AM   in reply to booyajamo
    in that thread example, I added this two lines to write the names to an array
    var arrayPrinterNames = []; // added
    for (var i = 0; i < iCount; ++i) {
              arrayPrinterNames.push(app.printerList[i].name); // added
    Mar 29, 2012 12:13 AM   in reply to CarlosCanto
    it also takes forever in my system, so I would add the following line
    var pL = app.printerList;
    and use pL to avoid multiple calls to the system. for example
              arrayPrinterNames.push(pL[i].name);
