Armand111
Adobe Photoshop Touch, Freeze on Startup
Mar 28, 2012 12:59 PM
Hey,
I have an iPad 3 with iOS 5.1 and 6 GB free space. I have reboot it many times and install and reinstall the app many times and also have leave the app for more than 2 hours and nothing happen.
The only thing i see is the logo of Photoshop Touch... not more. Is this a common problem and i hope someone have an idea how to solve this problem.
I have no apps in background and also try an fresh restore with only one app = PST... nothing.
Hope someone has an solution
Mfg Armand
    Mar 28, 2012 1:10 PM   in reply to Armand111
    Is your Ipad connected to internet...if yes is it possible to switch it off for few seconds and then check.
    Also, Do you have any theme installed on your Ipad which may be causing the issue.change to default theme and check.
    Mar 28, 2012 2:05 PM   in reply to Armand111
    Have you tried a reset ? Press and hold both the sleep and home buttons for about 10 to 15 seconds (ignore the red slider), after which the Apple logo should appear - you won't lose any content, it's the iPad equivalent of a reboot.
    If this doesn't work then the only other thing that comes to mind for me would be a factory reset. You might want to backup your apps through iTunes on your Mac before going through the process to make reinstalling easier. Apple would most likely be able to assist you with the steps if needed. I would also be curious if you had any issue with other apps or programs freezing or running slow on the device.
    Mar 29, 2012 10:42 AM   in reply to Armand111
    Can you please collect the crash log and upload it on "Pastebin.com"
    To find a log file, please sync your iPhone, iPod or iPad first, then locate the correct log file for the app using the path for your OS below. The log file’s name should start with the app’s name.
    OS X
    ~/Library/Logs/CrashReporter/MobileDevice/<your iPhone’s name>/
    Mar 29, 2012 12:22 PM   in reply to Armand111
    Is it possible for you to share and post the link here.
    Mar 30, 2012 10:38 AM   in reply to Armand111
    I think you have restored your Ipad using the itunes , can you reset your Ipad to the factory defualt settings and after that install just the photoshop touch and check.
    Mar 31, 2012 1:26 AM   in reply to Armand111
    Bitte auf Deutsch
    Von meinem iPhone gesendet
    Am 31.03.2012 um 10:21 schrieb Armand111 <forums@adobe.com>:
    Re: Adobe Photoshop Touch, Freeze on Startup
    created by Armand111 in Adobe Photoshop Touch - View the full discussion
    I did it and its not working… what about my crashlog? Did it helped?
    Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page: Re: Adobe Photoshop Touch, Freeze on Startup
    To unsubscribe from this thread, please visit the message page at Re: Adobe Photoshop Touch, Freeze on Startup. In the Actions box on the right, click the Stop Email Notifications link.
    Start a new discussion in Adobe Photoshop Touch by email or at Adobe Forums
    For more information about maintaining your forum email notifications please go to http://forums.adobe.com/message/2936746#2936746.
  • greule
    Oct 14, 2010
    Mar 31, 2012 2:24 AM   in reply to Armand111
    Unfortunately the problem is not quite clear from the crashlog.
    Can you do me the favor and try to only sync via iTunes PSTouch to your iPad. Just to exclude if we have a conflict with one of your installed apps.
    Please let me know the result on this.
    Guido
  • greule
    Oct 14, 2010
    Apr 1, 2012 5:44 AM   in reply to Armand111
    Interesting. Can you try to install from app store.
    Maybe there went something wrong while first initial
    install.
    Guido
    Sent from my iPhone
    Apr 6, 2012 4:51 PM   in reply to Armand111
    Thanks for the update, glad to hear that fixed it
    May 30, 2012 10:58 PM   in reply to Armand111
    I have this problem as well, have tried everything with no luck. Is there an actual workaround?
    Nov 30, 2012 6:14 PM   in reply to keepsakephotoAust
    After the recent update on November 28th, this problem is back. It is unfortunate, because I really need a file stored in the app. Is Adobe working on a update to fix this very same problem? Is it possible to get my file?
  • greule
    Oct 14, 2010
    Dec 1, 2012 3:14 AM   in reply to vtwolfe
    Hi. Have you tried to reboot your device? Are you on
    Android or iOS?
    Dec 1, 2012 8:24 AM   in reply to greule
    iPad 3 "New iPad" with iOS 6.0.1 and yes I tried both a reboot and a restore with iTunes.
  • greule
    Oct 14, 2010
    Dec 3, 2012 12:33 AM   in reply to vtwolfe
    Did you try to re-install via the "App Store"-app on your iPad? Hope that helps. -Guido
    Dec 3, 2012 7:17 AM   in reply to greule
    I was afraid to do this and fear loosing my files stored in the App. Please let me know if this might happen?
  • greule
    Oct 14, 2010
    Dec 3, 2012 7:35 AM   in reply to vtwolfe
    That might happen, but you can use iExplore (trial version) to backup your PSTouch files upfront http://www.macroplant.com/iexplorer/?utm_expid=15979170-8
    See my attached screenshot where to find the psdx (PS Touch) files. Hope that is helping you.
    Dec 3, 2012 10:04 AM   in reply to greule
    Awsome, I found the files, backed them up and reistalled the app. Everything is working great! Thanks greule!
  • greule
    Oct 14, 2010
    Dec 3, 2012 10:10 AM   in reply to vtwolfe
    Great. Glad that it worked for you.
