tony1421
Business cards
Mar 27, 2012 7:03 PM
where do I go to create business card on photoshop elements 10?
    Mar 27, 2012 8:47 PM   in reply to tony1421
    This is the PREMIER Elements forum, you need the Photoshop Elements forum
    How to Select a Forum http://forums.adobe.com/docs/DOC-1015
    Mar 28, 2012 10:55 AM   in reply to tony1421
    Welcome to the forum, though, as John T. states, it's the wrong forum.
    While business cards can be created in Photoshop, and probably Photoshop Elements, if you are doing much of that work, you should look into a page layout program, such as Adobe InDesign, as it will do a better job. You can do your Images in PS/PSE, but for the layout, and Type handling, InDesign will do a much better job.
    If you are handing off your creation to a commercial printer, you will probably be best doing that as a high-resolution PDF. If you are printing the business cards yourself, on an inkjet printer, say using the Avery Clear-Edge business card stock, it will not be so important.
    One possible problem, if going to a commercial printer from PSElements, is that it can only work in RGB Color Mode, where most commercial printers will want CMYK Color Mode, and PSE cannot work in CMYK - but Photoshop can.
    Good luck, and the PSE forum folk will be able to help you.
    Hunt
    Mar 28, 2012 2:00 PM   in reply to tony1421
    As long as you do not need CMYK Color Mode, then Photoshop Elements should be able to do what you want. There might even be a business card Template in PSE, and the people in that forum can tell you.
    Good luck,
    Hunt
    Mar 28, 2012 2:13 PM   in reply to tony1421
    Tony,
    You have to ask that question in the Photoshop Elements Forum. This forum is dedicated to the video editor, Premiere Elements.
    Good luck,
