I need multiple subforms to appear based on what is selected from a dropdown. I have 7 specified item values, if the person selects Item 1, I would like Item 1 subform to appear.
if the person selects Item 2 or Item 3 as well. I would like for those subforms to appear as well.
How do I go about doing that?
Also, I would like for the items to not appear on dropdown list once selected. I know the JavaScript will need to appear in the "change" event.
I need some help!
Solved! Go to Solution.
Total Likes
Hi There
I have created an example for for this which can be foudn here
Based on what you have asked I have done a simple example with 2 subforms. If you select option from from the dropdown subform 1 will be shown then if you select dropdown option 2 subform 2 will be displayed
I have also added check boxes as an alterative method.
check out the example at
http://www.dubdubdubdesigns.co.uk/livecycle/show-hide_subform.html
Regards
Graham
DubDubDubDesigns.co.uk
Total Likes
Hi There
Regards
Graham
Total Likes
Thank you so much!
Total Likes
