dovidc
IE9 not unloading flash app when camera is on      and the user leaves the page
Mar 28, 2012 6:10 PM
Tags: #flash #windows #flash_player #internet_explorer_9
If an IE9 user has their camera on and attempts to leave the webpage, the flash app stays loaded and the camera stays on.  Clearly this is an issue as the user has left the page.  Is there a good way to ensure that the flash app unloads and the camera turns off?
  • Chris Campbell
    May 4, 2010
    Mar 28, 2012 6:15 PM   in reply to dovidc
    Do you have a site where this happens?  I just gave http://www.testwebcam.com/ a try and after verifying that the camera is on (cam light on) I navigated away using both the back button and the address bar in IE9 and the camera turned off immediately in both cases.
    Is this new behavior for you with our 11.2 release?
    Chris
    Mar 29, 2012 3:28 PM   in reply to dovidc
    Hi Chris,
    Just an additional note:
    It's more than just having the camera on. The app in question is also publishing the camera feed to an FMS.
    I'm guessing the app at testwebcam.com is not publishing to an FMS.  When we see this problem, it's also possible to hear audio from other streams that our Flash app might be subscribing to (also coming from an FMS).
    We've tried using the javascript onbeforeunload event to force a graceful shutdown, with mixed results. For example, with the onbeforeunload handler, if I navigate to google.com the google page loads very quickly and doesn't seem to allow enough time to tirgger the graceful shutdown.
    May 15, 2012 10:00 AM   in reply to Chris Campbell
    We are currently experiencing this same issue as described by Chris. You can navigate away from the page that contains the flash, but the NetConnection and NetStream will persist and continue to publish a stream to either FMS or Wowza. It happens inconsistently, but does appear to be an issue with IE, Flash, the camera and publishing.
  • Chris Campbell
    May 4, 2010
    May 15, 2012 6:45 PM   in reply to WesleyJohnson
    Wesley,
    Could you please open a new bug report on this over at bugbase.adobe.com?  Please post back with the URL so that others affected can add their comments and votes.
    Chris
    May 16, 2012 6:52 AM   in reply to Chris Campbell
    Thanks, Chris. This is the first time I've submitted a bug, so I hope I've provided enough information. The link is: https://bugbase.adobe.com/index.cfm?event=bug&id=3191635.
    Thanks again,
    Wes
  • Chris Campbell
    May 4, 2010
    May 18, 2012 2:42 PM   in reply to WesleyJohnson
    Thanks Wes.  It looks good.
    Chris
    Nov 6, 2012 2:59 PM   in reply to Chris Campbell
    In IE 9 open http://www.testwebcam.com/ then open another tab to any page, then close the the testwebcam tab. My cam stays on, and same with many other systems that Ive tested. This is an issue in my case where I have a multi-widow webinar / chat app, as soon as I start up a cam for a private chat then close the window the cam is not released and negatively impacts the main webinar flash video. I've created loader swf's and beforeunload external interface calls to try and combat this without any success. Only cure is to close down all IE windows.
  • Chris Campbell
    May 4, 2010
    Nov 6, 2012 3:58 PM   in reply to Tony.Ortega
    Thanks for bringing this up again.  I've asked the team to take a look at the original bug, fwiw, I was also able to repro this with IE 10.
    Nov 23, 2012 4:42 PM   in reply to dovidc
    We are seeing this issue again as well.  Chris, is there any update on this?
  • Chris Campbell
    May 4, 2010
    Nov 27, 2012 6:40 PM   in reply to jefffluhr
    Pinging the team again
