need help to create a text layer using scripting
Mar 28, 2012 6:07 PM
hi,guys
i'm new in scripting. now i want to use scripting to create a text layer,but i don't know how to set some properties, does anyone can help me.
please see my code below:
var myLayer1 = docRef.artLayers.add();
myLayer1.kind = LayerKind.TEXT;
myLayer1.name='madison';
myLayer1.textItem.font='BodoniBT-Bold';
myLayer1.textItem.size='26.3203234863281 pt';
var textColor1 = new SolidColor;
textColor1.rgb.hexValue = 'FAF9EF';
myLayer1.textItem.color = textColor1;
myLayer1.textItem.contents = 'madison';
docRef.activeLayer.translate(1120.0000000, 649.0000000);
now i want to set justification , bounds.
another question is if my text has "\n" how to do?
thanks.
  • JJMack
    Jan 9, 2006
    Mar 28, 2012 8:15 PM   in reply to michael.shen
    I have played a bit with addinf text layers.  Had a few problems sizeing text Photoshop seem to want to use points and a 72 DPI resolution. I also find it hard to move or align a text layer the has been added as a paragraph in some boundry, Here is some comments and code I have in one of my scripts where i playe around tryinf to do text, note several settinf lines have been commented out
    /* Trying to figure out font size for the number of lines to cover the document height*/
    /* and getting setting text area to cover the document was a trip. Adobe Postscript trip*/
    /* I believe that 72 or 72.27 Point/Pica Size Photoshop Preference maybe I should see if*/
    /* I could retrieve it. Anyway mine is set to 72 Setting the document resolution taking*/
    /* the document width and dividing by 72 would probably yield number of characters that*/
    /* would fit in the document width. Setting the documents resolution comes into play*/
    /* with Photoshop text support. Using the documents height and dividing the by the number*/
    /* of lines of text I needed I hoped would yield the font size I needed. However that
    /* did not work the text area was correct the number of text lines did not fit. I needed*/
    /* to use a smaller font.  When the document resolution is set to 72 DPI and I set a text*/
    /* layer font size to 72 and the text area the number of pixels I want and observing
    /* Photoshop's text options bar there I see a one 1 to one relationship. 72 px = 72 px.*/
    /* If I set the documents resolution lower and set a Photoshop text layer font size to*/
    /* 72 px I see Photoshop scale the number to a lower number of pixels in the option bar.*/
    /* Just what I needed. Setting the Documents resolution to 60 DPI let the number of line*/
    /* I needed fit on the document. However Photoshop also scaled the text area I set down*/
    /* in size and that number of lines did not fit within that area. I needed to scale the
    /* text area up. Scaling the Text area up using 72/resolution did the trick...
                        text_layer = doc.artLayers.add();                                                             // Add a Layer
                        text_layer.name = "EXIF Stamp";        // Name Layer
                        text_layer.kind = LayerKind.TEXT;                                                             // Make Layer a Text Layer
                        text_layer.textItem.color = textColor;                                                            // set text layer color
    /* Do not set TextType to Pargarph Text for StampEXIF so action can position text layer
                         text_layer.textItem.kind = TextType.PARAGRAPHTEXT;                                        // Set text layers text type
                        text_layer.textItem.font = fontName;                                                            // set text font
                        text_layer.blendMode = BlendMode.NORMAL                                                             // blend mode
                        text_layer.textItem.fauxBold = false;                                                            // Bold
                        text_layer.textItem.fauxItalic = false;                                                            // Italic
                        text_layer.textItem.underline = UnderlineType.UNDERLINEOFF;                              // Underlibn
                        text_layer.textItem.capitalization = TextCase.NORMAL;                                        // Case
                        text_layer.textItem.antiAliasMethod = AntiAlias.SHARP;                                        // antiAlias
    //                    var fontSize = Math.round((doc.height- textY) / ((numExifItems +1) * sizeFactor)); // Calulate font size to use Item nomber + last \r
                        /* Calulate font size to use for StampExit keep size same for landscape and portrait base on document size */
                        if (doc.width >= doc.height) {var fontSize = Math.round(doc.height / (30 * sizeFactor));}
                        else {var fontSize = Math.round(doc.width / (30 * sizeFactor));}
                        if (fontSize<10){fontSize=10};        // don't use Font size smaller then 10
                        text_layer.textItem.size = fontSize;                                                            // set text font Size
    //                    text_layer.textItem.position = Array(textX, textY );                                        // set text layers position in and down
                        text_layer.textItem.position = Array(textX, (textY + fontSize ));                    // set text layers position in and down for Stamp add in fontsize
                        textWidth = ((doc.width - textX) * 72/testres );                                        // Text width document width - offset
                        textHeight = ((doc.height - textY) * 72/testres );                                        // Text height document height - offset
    /* Do not set Text Area for StampEXIF so action can position text layer
                        text_layer.textItem.width = textWidth;                                                            // set text area width
                        text_layer.textItem.height = textHeight;                                                  // set text area height
    text_layer.textItem.contents =  "Picture  " + docName + "  Copyright \u00A9 " + Biz + " " + cpyrt
    + "\r" + Artist + phoTime
    + "\r" + Model  + lens + maxF + focLength
    + "\r" + expPgm + expCmp + mtrMode + ev
    + "\r" + wbMode + ISO  + expTime + Fstop + flshMode;
    Mar 28, 2012 11:51 PM   in reply to michael.shen
    Does
    myLayer1.textItem.justification = Justification.LEFT;
    or the appropriate property not work?
    And for PointText you could set the coordinates with an Array of two values
    myLayer1.textItem.position = [100, 100];
    Mar 31, 2012 4:36 PM   in reply to michael.shen
    If your text has newlines, you must substitute them for "\r":
    var text = "line 1\nline2";
    text = text.replace("\n", "\r");
