sunderland19
Panorama in CS6
Mar 28, 2012 9:25 PM
Tags: #cs6 #suggestion #photoshop_cs6_beta #cs6-beta
I have been trying to create a Panorama in CS6 the past couple of days. When it said I didn't have enough Ram the first time I went through my hard drive and got rid of a lot of things and also freed up a lot of space. I am still getting the same box when I try to use the selection tool to do the fill. It says cannot use automatic selection tool because there is not enough Ram. So am I doing something wrong? I am new to Photoshop and am trying this out for the first time. Thanks for your help.
    Mar 28, 2012 10:51 PM   in reply to sunderland19
    RAM = Memory on board for loading and processing programs
    Hard drive = Storage device for data. This is the location some programs are able to emulate RAM (swap/page files).
    Very different items. Access to RAM is very, very much faster.
    If a program doesn't find enough RAM memory it doesn't do any good (in most cases) to clean up the hard drive.
    How much RAM do you have installed and how much is allocated to CS6? Go to "Edit -> Preferences -> Performance" to find out.
    Ciao, Walter
  • Trevor.Dennis
    May 24, 2010
    Mar 29, 2012 2:42 AM   in reply to sunderland19
    If you are short on RAM, then appart from closing all other programs, you could downsize the source files (by the same amount, of course) before merging.
    Mar 29, 2012 11:18 AM   in reply to sunderland19
    We still don't know if you have a real problem with your RAM or if it is software related. It's beta, after all and therefore definitely prone to such kind of hickups. So please tell us the numbers for RAM and dedicated memory for CS6.
    Ciao, Walter
    Mar 29, 2012 12:19 PM   in reply to sunderland19
    We'd need a lot more info. The best way, follow these directions:
    FAQ: How do I share my System Information?
