i have the following AS class file:
package {
public class DropImage {
public function DropImage() {
package{
import flash.display.MovieClip;
import flash.events.Event;
import flash.net.URLLoader;
import flash.net.URLRequest;
import com.greensock.TweenNano;
import com.greensock.easing.*;
public class DropImage extends MovieClip {
private var containerArray:Array = new Array ;
private var totalImgs:int = -1;
private var counter:uint = 0;
private var imageLength:uint;
//Loads the xml
var xmlLoader:URLLoader = new URLLoader ;
xmlLoader.load(new URLRequest("DropImages.xml"));
xmlLoader.addEventListener(Event.COMPLETE,xmlLoaded);
//Creates new instances of the ImageContainer class with the y position
//initally set off the stage and the rotation at -90. The -90 rotation
//gives the dropping effect as the object gets tweened downwards.
private function xmlLoaded(e:Event):void {
var xml:XML = new XML(e.target.data);
imageLength = xml.image.length();
for (var i:int = 0; i < xml.image.length(); i++) {
var imgc:ImageContainer = new ImageContainer(xml.image[i].attribute("src"));
imgc.x = 100;
imgc.y = -133;
imgc.rotation = -90;
imgc.alpha = 0;
imgc.addEventListener("imageloaded",showImage);
addChild(imgc);
containerArray.push(imgc);
//waits for all images before tweening
private function showImage(e:Event):void {
totalImgs++;
if (totalImgs == imageLength - 1) {
tweenBox();
//tweens the images downwards to a randoms rotation between -11 and 11
//and replays the tween after two seconds.
private function tweenBox():void {
TweenNano.to(containerArray[counter],1, {y:192.45,
rotation:Math.floor(Math.random() * 11) - 11,
alpha:1,
ease:Sine.easeOut,
onComplete:function(){
if(counter != containerArray.length - 1){
counter++;
TweenNano.delayedCall(2, tweenBox);
It sais '1037: Packages cannot be nested' and if i click the error it goes to line 7 of the scrip..help please?
3
as3 Class files all follow the same general format listed below.
p.s. that's as3, not as1,as2.
p.p.s. format your code so it's legible.
