Clear thing not very clear ...
Mar 27, 2012 8:28 PM
Would anyone be kind enough to tell me what errors I am doing ?
I don't understand why my boxes in the footer are shifting to the bottom ..
Also, I would really like to understand once and for all how clearing works (but please do not point me to some adobe tutorial as many of them are not that clear ...I am having some issues trying to understand all that "clear " "thing , when to clear right or left , display block (from I learned adding the display:block should automatically make a div position beneath another one, but it does not happen when I try to do it and always end up with a div overlapping another one and going crazy about it ....
Many thanks in advance !
The link to see the issue this post is about is http://elhoster2.com/hostelinn
    Mar 27, 2012 11:57 PM   in reply to valf
    Mar 28, 2012 12:02 AM   in reply to valf
    This has quite a straightforward explanation of the clear property in it.  It looks a bit scary but it is worth a read.
    http://www.w3.org/wiki/Floats_and_clearing
    Martin
    Mar 28, 2012 12:37 AM   in reply to martcol
    A good tip to help clear floats properly is to add overflow:hidden to the containing element.
    Common use for example is a nav menu where the CSS would be
    ul { overflow:hidden;}  /* the containing element */
    li { float:left;}  /* the floated element */
    Without the over overflow:hidden; you can have problems adding borders and setting margins. It also clears the float and allows the elements below to flow as they should in the HTML. This method also means no extra unnecessary mark up and therefore cleaner code.
    Hope that helps you.
    Mar 28, 2012 1:54 AM   in reply to valf
    1. Run the code through the w3 validator is a good way to find problems and here is yours
    2. Line 121, Column 126: Stray end tag div.…r box 1</div></div><div class="box-4 footer-box">footer box 1</div></div></div>
    3. Line 121, Column 132: Stray end tag div.…r box 1</div></div><div class="box-4 footer-box">footer box 1</div></div></div>
    Mar 28, 2012 1:01 PM   in reply to valf
    The Magic of Overflow-Hidden (to contain floats and keep margins from collapsing).
    http://colinaarts.com/articles/the-magic-of-overflow-hidden/
    Nancy O.
    Alt-Web Design & Publishing
    Web | Graphics | Print | Media  Specialists
    http://alt-web.com/
    Mar 29, 2012 12:34 AM   in reply to valf
    You have them outside the 'grid-centered' div. I've changed it to this
    <div class="footer">
    <div class="grid-centered" style="height:280px;">
    <div class="newsletter">
    <h4 style="color:white">Newsletter</h4>
    <p>
    <input type="text" value="Enter any Valid Email Address" name="s" onblur="if(this.value == '') { this.value = 'Enter any Valid Email Address'; }" onfocus="if(this.value == 'Enter any Valid Email Address') { this.value = ''; }" class="textfield">
    </p>
    <p>
    <input type="submit" value="Submit" class="go backcolr">
    </p>
    </div>
    </div>
    <div class="box-4 footer-box">footer box 1</div><div class="box-4 footer-box">footer box 1</div>
    </div>
    </div>
    That works in chrome dev tools anyway.
    I won't add anymore float advice as my first tip covered that more than enough to help you work with floats.
