Hello
All right, I know it's 2012, but I've just inherited a MacPower G4 and would like to run Photoshop on it. My previous experience is with Photoshop 7 on PC.
From what I understand the latest version of Apples OS the G4 will run is 10.4. I think that means the latest version of Photoshop I can use is CS2. the machines got about 1.2GB RAM, but it's the pre-Intel version.
My question is how I might go about finding a legitimate version of CS or CS2? I have read the horror stories about eBay versions of the software and am not confident going that route.
Aside from stumbling across someone lovely with a legitimate version who is willing to transfer the license and fill in the forms, is there a trusted place that sells or resells genuine, older versions of PS?
Scott
iIf you last used PS7 and were OK with that I would really suggest you buy, or at least take a trial, of Photoshop Elements. Believe latest is version 10. It is only $100 so a lot cheaper than Photoshop and the learning curve not as steep.
It will probably have more features than your old PS7, and should run just fine on an older machine.
Buying a legitimate version of CS2 may be difficult for the reasons you mentioned.
I have an old G4 Mac with 2GB RAM and CS3 on it. I believe it is about 10 years old now. It could run 10.5 but I only upgraded it to 10.4. It sits in my attic as a backup. It is terribly slow, even with small web size graphics. It cannot even display YouTube videos smoothly. You can find similar models on eBay for $50. Cheap $200 netbooks probably have more oomph than that G4.
Do not think that you've inherited anything beyond the usefulness of nostalgia. I'm all for trying to get the most out of technology before it hits the landfill but you will waste much time and money trying to rehabilitate something so old.
If you are willing to consider the limitations of Elements, then you probably would have no issue with installing GIMP for free.
Marian
I'm not a heavy user of the full range of PS capabilities - I generally prefer to get things right in camera, but I have built actions around creating lomographic effects, cross-processing etc. I've also used PS to design flyers, laying images and text, so have some use of that sort of functionality.
Much of that has been done on a Netbook, as it happens, but what the G4 offers, presumably, is a capability professional graphic designers and photographers were using just 7 or 8 years ago. If only it was still possible to get the software, that would be good enough for me. And without, of course spending money that really ought to be earmarked for the new baby on a new Mac and associated software!
I've not used Elements, so will reflect on Curt's advice and maybe try a trial version. If you can dodge. Burn, manipulate curves, build layers, play around with saturation etc. then maybe that will be enough.
S
Sent from my iPhone
The last G4 Power Mac was introduced 9 years ago in 2003. That's as old as the Iraq war and older than Facebook. Better digital cameras of that day were ~5 megapixels. If you are limiting yourself to smaller images then you might be able to tolerate that Mac.
Buying old software is truly messy. This is complicated by activation. That license that you think has been purchased legitimately as pre-owned software still has to be activated by Adobe. By the time you discover that it cannot be activated, your transaction with the seller is complete and you cannot get a refund.
Mac is not essential for the professional graphic designer and photographer. One can use Windows computers at a much lower cost.
Speaking of v7, I've been wanting to install my old copy of this, to run an old plugin that was never developed past v1.0 (Xaos Segmation). I've read that there are issuses installing Pshop v7 on a modern system, particularly with today's larger disk drives. Can anyone enlighten me as to what the specifics are?
I do have an older laptop with XP on it that I use for my scanning (Microtek apparently will not be releasing a 64-bit driver for my ScanMaker 9800), but it shuts down spotaneously at random times - sometimes it'll run for days, other times, it shuts down seconds after booting.
If I put Photoshop on it, I'd likely end up here asking, "Can I recover from a .TMP file after a crash?" ![]()
