rramos00002
How do you warp around two or more fields?
Mar 29, 2012 8:19 AM
Tags: #acrobat_10_pro
I have a document with several fields but want to set a wrap around so I dont's have to jump to each field individually.
    Mar 29, 2012 10:08 AM   in reply to rramos00002
    You can use the "setFocus" method in the "On Blur" action to direct to the other field or you can set the specific tabbing order.
    If the fields have a fixed length and the inputted data is always that length, then you can write function to check the length of the entered text and last keystroke and if that is maximum number of characters allowed, then use the 'setFocus' method to jump to the next field.
Bookmarked By (1)
