Verify e-mail address field is not null.
Mar 29, 2012 11:11 AM
I am trying to get the script below to verify the "ReleasedIntoSystemBy" field (drop-down with email address values) is not blank. What have I got wrong?
// Declare the variable
var vEmail;
var vSubject = "New Work Order/Project Authorization"
var vBody = "Instructions:"
// Check that the email field is not null
if (xfa.resolveNode("#subform[0].#subform[2].Table111[1].Row1.ReleasedIn toSystemBy").rawValue !== null) {
     vEmail = xfa.resolveNode("#subform[0].#subform[2].Table111[1].Row1.ReleasedInt oSystemBy").rawValue;
// Send email
event.target.submitForm({cURL:"mailto: " + vEmail + "?subject=" + vSubject + "&body=" + vBody,cSubmitAs:"PDF",cCharset:"utf-8"});
    Mar 29, 2012 11:25 AM   in reply to DKinsley
    The script looks correct however, you are doing //Send Email script whether or not the vEmail value is null as it lies outside the if statement
    I''m assuming you want to send if vEmail is not null.  If that is the case then place the //Send Email script within the if statement.
    Mar 29, 2012 11:36 AM   in reply to DKinsley
    Here you go
    var vEmail;
         // Send email
    }else{
    //displays message box warning user to fill in field
    xfa.host.messageBox("Please fill the email field");
    //sets the focus to the field
    xfa.host.setFocus(xfa.resolveNode("#subform[0].#subform[2].Table111[1 ].Row1.ReleasedIntoSystemBy"));
    Mar 29, 2012 12:26 PM   in reply to DKinsley
    if you execute the below script it will check all validations on the form such as required fields
    xfa.form.form1.execValidate()
    form1 being the top node of you hierarchy
    it will return a true or false, true if validatations are all fullfilled or false if not
    In your script you could add an if statement similar to this
    if(xfa.form.form1.execValidate() == true){
      //within here execute your above email script
