Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
SOLVED
Verify e-mail address field is not null.
Avatar
Level 9
I am trying to get the script below to verify the "ReleasedIntoSystemBy" field (drop-down with email address values) is not blank. What have I got wrong?
// Declare the variable
var vEmail;
var vSubject = "New Work Order/Project Authorization"
var vBody = "Instructions:"
// Check that the email field is not null
if (xfa.resolveNode("#subform[0].#subform[2].Table111[1].Row1.ReleasedIntoSystemBy").rawValue !== null) {
     vEmail = xfa.resolveNode("#subform[0].#subform[2].Table111[1].Row1.ReleasedIntoSystemBy").rawValue;
// Send email
event.target.submitForm({cURL:"mailto: " + vEmail + "?subject=" + vSubject + "&body=" + vBody,cSubmitAs:"PDF",cCharset:"utf-8"});
1 Accepted Solution
Avatar
Correct answer by
Level 2
Here you go
var vEmail;
if (xfa.resolveNode("#subform[0].#subform[2].Table111[1].Row1.ReleasedIn toSystemBy").rawValue !== null) {
     vEmail = xfa.resolveNode("#subform[0].#subform[2].Table111[1].Row1.ReleasedInt oSystemBy").rawValue;
     // Send email
}else{
//displays message box warning user to fill in field
xfa.host.messageBox("Please fill the email field");
//sets the focus to the field
xfa.host.setFocus(xfa.resolveNode("#subform[0].#subform[2].Table111[1].Row1.ReleasedIntoSystemBy"));
Avatar
Level 2
The script looks correct however, you are doing //Send Email script whether or not the vEmail value is null as it lies outside the if statement
I''m assuming you want to send if vEmail is not null.  If that is the case then place the //Send Email script within the if statement.
Avatar
Level 9
Yes - you are correct. I did as you suggested and changed it as seen below. Now it does nothing when blank. Is it possible to generate a message telling the user they left that field blank?
var vEmail;
     // Send email
Avatar
Correct answer by
Level 2
Here you go
var vEmail;
     // Send email
}else{
Avatar
Level 9
Is there a way to have the required fields verfied that they are populated before the custom email button executes?
Thanks again for your help!
Avatar
Level 2
if you execute the below script it will check all validations on the form such as required fields
xfa.form.form1.execValidate()
form1 being the top node of you hierarchy
it will return a true or false, true if validatations are all fullfilled or false if not
In your script you could add an if statement similar to this
if(xfa.form.form1.execValidate() == true){
  //within here execute your above email script
Avatar
Level 9
Having trouble - is this correct?
var vEmail;
// Send email
Avatar
Level 9
I got it working - thanks again!
