Reader Extensions ES WebApp
Avatar
Former Community Member
Hi all,
I have a problem when I try to reader extend a form using Reader Extensions webapp (http://[host]:[port]/ReaderExtensions).
I can upload the form, select the rights and then when I click "Apply", the progress / waiting bar "Download" keep running and nothing happens.
Did anyone ever encoutered this issue ?
Is there a solution ?
Thomas
Avatar
Does this problem occur with all forms and documents that you ry to Reader Extend?  Have you checked the server log file to see if any exceptions are being thrown?
Regards
Steve
Avatar
Hi Steve,
First of all, thanks for your response
This problem seems to occur with all pdf files that I try to upload (tested 5 of them so far). There is absolutely nothing in the server log ...
I tested connecting to RE from my computer and directly from the server, both have the same problem.
I'm using ReaderExtensions V8.0 by the way.
Thomas
Avatar
Level 2
Flash Player 10 broke the Reader Extensions sample application included with LiveCycle ES 8.0.1, and 8.2.1. When you use it, it will essentially hang. The workaround is to revert back to Flash Player 9 on those machines you use as LiveCycle clients.
This problem has been fixed in LC 8.2.1 SP3 as well as in ES2.
