fpsabatte
Page range greyed out?
Mar 29, 2012 2:49 PM
Tags: #page_range
Just upgraded Illustrator to CS5 from CS3.  I want to print two specific pages from a multi tiled document but the 'page range" option under "General" is grayed out.  I never ran into this problem before CS5.  I appreciate any advice.
Frank
    Mar 29, 2012 3:09 PM   in reply to fpsabatte
    Is it truely a tiled document or do you instead have artboards instead? This is what you see with artboards (notice lower left)
    This is a tiled document
    Mar 30, 2012 8:45 AM   in reply to fpsabatte
    I see what you mean. Did you make the file or is it something you were given. You might have to remake the file using Artboards set to 0 gutter and copy/paste the artwork from the artboard in the original file to the new file. Sorry I didn't explore further.
    Mar 30, 2012 3:28 PM   in reply to fpsabatte
    Don't you see it un larry's screenshot at the bottom it says Tile?
    Then it has a check box next to Tile Range check that box for a range of your tiles.
    The pages only gives you all because you only have one artboard so it is not possible to have a range that way.
    You need to select a arange of your tiles not pages
    Mar 30, 2012 6:05 PM   in reply to fpsabatte
    You're welcome!
