How to convert a text to a list
Mar 29, 2012 4:31 PM
I have a text with numbers like this: 24 12 4 65 33 etc (with no itemDelimiter).
I neet to sort this numbers, maybe I need to convert this text in a list, so how can I do to convert a text in a list?
Thanks.
    Mar 29, 2012 8:32 PM   in reply to Jhon Carlo
    You could try setting the itemDelimiter to SPACE, then walk through your string item by item dropping the values into a list:
    on split str, pat
      tDelim = the itemDelimiter
      the itemDelimiter = SPACE
      tList = []
      nItems = str.item.count
      repeat with i = 1 to nItems
        tList.append( value(str.item[i]) )
      end repeat
      the itemDelimiter = tDelim
      return tList
    end
    Then you can sort the list returned and do what you want with it.
    Mar 30, 2012 12:58 PM   in reply to Sean_Wilson
    for completeness, here's a javascript implementation:
    function js_split(str, delim) {
      var tmpList = list();
      var arr = str.split(delim);
      for (var i in arr) tmpList.add(parseInt(arr[i]));
      return tmpList;
