I'm having an issue with the PDFMaker plugin in acrobat X across multiple sites and clients.
Common factor is:
Windows 7 64bit
Office 2010 32bit.
On ALL machines, the PDFMaker COM addin, whether in Word, Excel, Powerpoint or Outlook will regularly crash the Print Spooler Service (ie it becomes unresponsive). It needs to be PSKilled before it can be recovered.
Disabling the COM addins and the systems are perfectly stable until, somehow, the PDFMaker COM addin mysteriously re-enables itself.
For Microsoft Excel it re-enables each time Excel is launched.
Even if the load behaviour registry key below is set the autoenabling exists
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Excel\Addins\PDFMaker.Of ficeAddin] "LoadBehavior"=dword:00000000
To preempt useless suggestions:
1 - latest updates installed
2 - users are local administrators
3 - application was installed as the local administrator
I'd like to know how to permanently disable the PDFMaker COM addin in all office applications without it ever coming back from Adobe updates.
Cheers
May try updating the Windows OS and MS Office as a troubleshooting step if you have not already done it.
Windows 7 and Windows Server 2008 R2 Service Pack 1 (KB976932)
http://www.microsoft.com/download/en/details.aspx?id=5842
Service Pack 1 for Microsoft Office 2010 (KB2460049) 32-bit Edition
You don't mention the Service Packs on you Microsoft products.
All systems are completely up to date. This is happening on dozens of Windows 7 64bit systems across half a dozen networks for as many clients. The only common thing is Windows 7 64bit, office 2010 32 bit and Acrobat X.
I am convinced that the problem is a QA one on adobe's part.
I've yet to see any update that states adobe has fixed the problem - i'd be very interested to see one that specifically states that they fixed PDF maker crashing the print spooler service on windows 7 64 bit.
I've worked around the issue by performing a change install of acrobat X and removing PDFmaker and all subitems.
I am having continuous problems of a similar nature. Starting just today, ALL of the PCs in my office are taking 15 to 20 minutes to create a simple pdf using acrobat x. Yesterday, everything was moving along quickly, but we 'updated'. What a joke.
We are all Windows 7 64 bit.
