LR4.1RC - Develop Module Blurring of image
Mar 29, 2012 8:41 PM
Tags: #bug #module #slow #develop #lr4
Hi there, installed LR4.1 and the develop module has got worse.  Every time I move a slider on any parameter the image goes blurry for about 5 seconds before returning to normal. This is especially noticeable when zoomed in
Most horrible to work with. What you've done please return it to the state of 4.0 or better
I'd rather have the dual monitor bug than this.
    Mar 29, 2012 10:08 PM   in reply to John Spacey
    This sounds very much like a bug if I read other users's experience with LR4.1
    Any chance you could try again and maybe try more situtations to see whether it occurs always?
    Mar 29, 2012 11:07 PM   in reply to slarti3
    I think what you seeing is the sharpening is temporarily turned off while the sliders are tracking.
    Mar 29, 2012 11:12 PM   in reply to simonsaith
    Simonsaith, will this get addressed in LR4.1, or is the turning off the sharpening a method to try to fix the speed issues?
    Mar 30, 2012 2:38 AM   in reply to simonsaith
    I don't like it.
    For me, it was fast enough with sharpening being adjusted in real time.
    The most annoying thing is that the sharpening does not get rendered even if you let go the the slider (e.g Exposure) — I have to move the mouse off the slider.
    Mar 30, 2012 2:44 AM   in reply to Dorin Nicolaescu-Musteață
    Dorin Nicolaescu-Musteață wrote:
    I don't like it.
    +1
    seems like a very unprofessionell fix too me if this is really because of the speed issues some people have.
    Mar 30, 2012 4:11 AM   in reply to John Spacey
    This is definitely disconcerting. 4.0 was better.
    Mar 30, 2012 4:58 AM   in reply to Dorin Nicolaescu-Musteață
    I don't like it.
    Yes, it seems to turn sharpening off when you move a slider, and keep it off while the mouse is over the slider.  Once you move the mouse off the slider, sharpening is rendered after about half a second.  I think it would be better to render after half a second of no slider movement even if the mouse is still over the slider.
    Mar 30, 2012 5:40 AM   in reply to CSS Simon
    If (and I don't know, just IF) this is what Adobe has done to deal with the 4.0 performance problems, then I think they have mis-read the problem.
    Its NOT a performance tweak -- performance is great in 4.0 for most people, but for a large group there is something
    very wrong.  This would indicate some kind of h/w or s/w or driver or ??? interaction that is causing extreme slowness
    for those people, but which simply does not exist for others.
    Tweaking something like "not applying some edits" during slider use is ignoring the real issue.
    Mar 30, 2012 6:28 AM   in reply to John Spacey
    Agree with others. Waiting for the adjustments to take place until I release the mouse is a no show. Simply not acceptable.
    Mar 30, 2012 8:05 AM   in reply to simonsaith
    Allowing the image to blur was a bad decision.  There's no other way to put it.
    Apr 1, 2012 9:45 AM   in reply to Danny Michael
    There seems to be 2 different issues here. The original poster is referring to the image going blurry until releasing the mouse. The other issue is the sharpening being turned off until releasing the mouse/moving off the slider.
    Two of us now have fixed the blurry issue by reinstalling 4.0, then redownloading RC1 and reinstalling it. We were both Mac users, one on 10.7.3 and one on 10.6.8. After doing this we are both no longer seeing the blurry previews until releasing the mouse and sharpening is now immediate, as expected. This is while in the Detail panel, using the sharpening slider.
    Hopefully this may help others.
    Apr 2, 2012 7:00 AM   in reply to John Spacey
    Is there a way, we process a claim (if not done already) so that Adobe knows that this is NOT acceptable ?
    Apr 5, 2012 10:42 AM   in reply to John Spacey
    After upgrading from 4.0 beta to 4.1 RC i can confirm that sharpening is removed from the image as long as you use a silder from the basic panel. You have to move the cursor off the slider area to see the sharpening re-applied. Everything else works fine here, also no speed problems. I hope the effect of the sharpening-remove will be corrected or we get at least an option in the preferences where we can set this "on" or "off", if this is really wanted for speed-improvement.
