Martin Klefas
Uncaught Javascript Exception during create file phase of Merge to HDR Pro.
Mar 30, 2012 5:50 AM
Tags: #exceptions #uncaught_exception #photoshop_cs6_beta #merge_to_hdr_pro #cs6-beta
Provide a descriptive title that includes your OS information:
I am trying to create an HDR file from several large merged panoramas, and everything seems to go very well whichever options I select until the point comes when photoshop tries to create the final file. The individual layers of the HDR are 40188x6848 and saved as PSB files, when loaded they fill the entire 8Gb of memory in my machine.
I am using Windows Vista 64, my graphics card is unsupported and so turned off, I have photoshop setup to use 3 scratch disks, and it appears to be using around 40Gb on the first one and none on others.
Provide concise, step-by-step details on how to reproduce the issue you are seeing.
  1. Select File > Automate > Merge to HDR Pro
  2. Select the 5 HDR layer files, check attempt to automatically align layers
  3. Make a cup of tea, you're in for a wait.
  4. Set the EV levels of the files
  5. Select any options you want from the next panel, I've tried most of them by now.
  6. Sit back and wait for the following screen:
Provide a description of the "Expected Result":
Photoshop should have brought up a file containing the merged images, which I could then save to disk.
Provide your System Info from Photoshop:
Adobe Photoshop Version: 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00) x64
Operating System: Windows Vista 64-bit
Version: 6.0 Service Pack 2
System architecture: AMD CPU Family:15, Model:15, Stepping:2 with MMX, SSE Integer, SSE FP, SSE2, SSE3
Physical processor count: 1
Processor speed: 1808 MHz
Built-in memory: 8062 MB
Free memory: 1083 MB
Memory available to Photoshop: 7149 MB
Memory used by Photoshop: 72 %
Image tile size: 132K
Image cache levels: 4
OpenGL Drawing: Disabled.
OpenGL Drawing Mode: Basic
OpenGL Allow Normal Mode: False.
OpenGL Allow Advanced Mode: False.
OpenGL Allow Old GPUs: Not Detected.
Video Card Vendor: NVIDIA Corporation
Video Card Renderer: GeForce 6150SE nForce 430/PCI/SSE2
Display: 1
Display Bounds:=  top: 0, left: 0, bottom: 1024, right: 1280
Video Card Number: 1
Video Card: NVIDIA GeForce 6150SE nForce 430
OpenCL Unavailable
Driver Version: 8.17.12.7533
Driver Date: 20110521050100.000000-000
Video Card Driver: nvd3dumx.dll,nvd3dum
Video Mode: 1280 x 1024 x 4294967296 colors
Video Card Caption: NVIDIA GeForce 6150SE nForce 430
Video Card Memory: 128 MB
Video Rect Texture Size: 4096
Serial number: Tryout Version
Application folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\
Temporary file path: C:\Users\MARTIN~1\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
  H:\, 279.5G, 57.9G free
  D:\, 149.0G, 121.9G free
  E:\, 74.5G, 13.9G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Required\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\
Additional Plug-ins folder: not set
Installed components:
   A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
   ACE.dll   ACE 2012/01/18-15:07:40   66.492997   66.492997
   adbeape.dll   Adobe APE 2012/01/25-10:04:55   66.1025012   66.1025012
   AdobeLinguistic.dll   Adobe Linguisitc Library   6.0.0
   AdobeOwl.dll   Adobe Owl 2012/02/09-16:00:02   4.0.93   66.496052
   AdobePDFL.dll   PDFL 2011/12/12-16:12:37   66.419471   66.419471
   AdobePIP.dll   Adobe Product Improvement Program   6.0.0.1642
   AdobeXMP.dll   Adobe XMP Core 2012/02/06-14:56:27   66.145661   66.145661
   AdobeXMPFiles.dll   Adobe XMP Files 2012/02/06-14:56:27   66.145661   66.145661
   AdobeXMPScript.dll   Adobe XMP Script 2012/02/06-14:56:27   66.145661   66.145661
   adobe_caps.dll   Adobe CAPS   5,0,10,0
   AGM.dll   AGM 2012/01/18-15:07:40   66.492997   66.492997
   ahclient.dll    AdobeHelp Dynamic Link Library   1,7,0,56
   aif_core.dll   AIF   3.0   62.490293
   aif_ocl.dll   AIF   3.0   62.490293
   aif_ogl.dll   AIF   3.0   62.490293
   amtlib.dll   AMTLib (64 Bit)   6.0.0.75 (BuildVersion: 6.0; BuildDate: Mon Jan 16 2012 18:00:00)   1.000000
   ARE.dll   ARE 2012/01/18-15:07:40   66.492997   66.492997
   AXE8SharedExpat.dll   AXE8SharedExpat 2011/12/16-15:10:49   66.26830   66.26830
   AXEDOMCore.dll   AXEDOMCore 2011/12/16-15:10:49   66.26830   66.26830
   Bib.dll   BIB 2012/01/18-15:07:40   66.492997   66.492997
   BIBUtils.dll   BIBUtils 2012/01/18-15:07:40   66.492997   66.492997
   boost_date_time.dll   DVA Product   6.0.0
   boost_signals.dll   DVA Product   6.0.0
   boost_system.dll   DVA Product   6.0.0
   boost_threads.dll   DVA Product   6.0.0
   cg.dll   NVIDIA Cg Runtime   3.0.00007
   cgGL.dll   NVIDIA Cg Runtime   3.0.00007
   CIT.dll   Adobe CIT   2.0.5.19287   2.0.5.19287
   CoolType.dll   CoolType 2012/01/18-15:07:40   66.492997   66.492997
   data_flow.dll   AIF   3.0   62.490293
   dvaaudiodevice.dll   DVA Product   6.0.0
   dvacore.dll   DVA Product   6.0.0
   dvamarshal.dll   DVA Product   6.0.0
   dvamediatypes.dll   DVA Product   6.0.0
   dvaplayer.dll   DVA Product   6.0.0
   dvatransport.dll   DVA Product   6.0.0
   dvaunittesting.dll   DVA Product   6.0.0
   dynamiclink.dll   DVA Product   6.0.0
   ExtendScript.dll   ExtendScript 2011/12/14-15:08:46   66.490082   66.490082
   FileInfo.dll   Adobe XMP FileInfo 2012/01/17-15:11:19   66.145433   66.145433
   filter_graph.dll   AIF   3.0   62.490293
   hydra_filters.dll   AIF   3.0   62.490293
   icucnv40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
   icudt40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
   image_compiler.dll   AIF   3.0   62.490293
   image_flow.dll   AIF   3.0   62.490293
   image_runtime.dll   AIF   3.0   62.490293
   JP2KLib.dll   JP2KLib 2011/12/12-16:12:37   66.236923   66.236923
   libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
   libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   10.0
   LogSession.dll   LogSession   2.1.2.1640
   mediacoreif.dll   DVA Product   6.0.0
   MPS.dll   MPS 2012/02/03-10:33:13   66.495174   66.495174
   msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
   msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
   msvcp100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
   msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
   msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
   msvcr100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
   msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
   msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
   pdfsettings.dll   Adobe PDFSettings   1.04
   Photoshop.dll   Adobe Photoshop CS6   CS6
   Plugin.dll   Adobe Photoshop CS6   CS6
   PlugPlug.dll   Adobe(R) CSXS PlugPlug Standard Dll (64 bit)   3.0.0.383
   PSArt.dll   Adobe Photoshop CS6   CS6
   PSViews.dll   Adobe Photoshop CS6   CS6
   SCCore.dll   ScCore 2011/12/14-15:08:46   66.490082   66.490082
   ScriptUIFlex.dll   ScriptUIFlex 2011/12/14-15:08:46   66.490082   66.490082
   tbb.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
   tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
   TfFontMgr.dll   FontMgr   9.3.0.113
   TfKernel.dll   Kernel   9.3.0.113
   TFKGEOM.dll   Kernel Geom   9.3.0.113
   TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
   updaternotifications.dll   Adobe Updater Notifications Library   6.0.0.24 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   6.0.0.24
   WRServices.dll   WRServices Friday January 27 2012 13:22:12   Build 0.17112   0.17112
   wu3d.dll   U3D Writer   9.3.0.113
Required plug-ins:
   3D Studio 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Accented Edges 13.0
   Adaptive Wide Angle 13.0
   ADM 3.11x01
   Angled Strokes 13.0
   Average 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Bas Relief 13.0
   BMP 13.0
   Camera Raw 7.0
   Chalk & Charcoal 13.0
   Charcoal 13.0
   Chrome 13.0
   Cineon 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Clouds 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Collada 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Color Halftone 13.0
   Colored Pencil 13.0
   CompuServe GIF 13.0
   Conté Crayon 13.0
   Craquelure 13.0
   Crop and Straighten Photos 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Crop and Straighten Photos Filter 13.0
   Crosshatch 13.0
   Crystallize 13.0
   Cutout 13.0
   Dark Strokes 13.0
   De-Interlace 13.0
   Dicom 13.0
   Difference Clouds 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Diffuse Glow 13.0
   Displace 13.0
   Dry Brush 13.0
   Eazel Acquire 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Embed Watermark 4.0
   Entropy 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Extrude 13.0
   FastCore Routines 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Fibers 13.0
   Film Grain 13.0
   Filter Gallery 13.0
   Flash 3D 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Fresco 13.0
   Glass 13.0
   Glowing Edges 13.0
   Google Earth 4 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Grain 13.0
   Graphic Pen 13.0
   Halftone Pattern 13.0
   HDRMergeUI 13.0
   IFF Format 13.0
   Ink Outlines 13.0
   JPEG 2000 13.0
   Kurtosis 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Lens Blur 13.0
   Lens Correction 13.0
   Lens Flare 13.0
   Liquify 13.0
   Matlab Operation 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Maximum 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Mean 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Measurement Core 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Median 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Mezzotint 13.0
   Minimum 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   MMXCore Routines 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Mosaic Tiles 13.0
   Multiprocessor Support 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Neon Glow 13.0
   Note Paper 13.0
   NTSC Colors 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Ocean Ripple 13.0
   Oil Paint 13.0
   OpenEXR 13.0
   Paint Daubs 13.0
   Palette Knife 13.0
   Patchwork 13.0
   Paths to Illustrator 13.0
   PCX 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Photocopy 13.0
   Photoshop 3D Engine 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Picture Package Filter 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Pinch 13.0
   Pixar 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Plaster 13.0
   Plastic Wrap 13.0
   PNG 13.0
   Pointillize 13.0
   Polar Coordinates 13.0
   Portable Bit Map 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Poster Edges 13.0
   Radial Blur 13.0
   Radiance 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Range 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Read Watermark 4.0
   Reticulation 13.0
   Ripple 13.0
   Rough Pastels 13.0
   Save for Web 13.0
   ScriptingSupport 13.0
   Shear 13.0
   Skewness 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Smart Blur 13.0
   Smudge Stick 13.0
   Solarize 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Spatter 13.0
   Spherize 13.0
   Sponge 13.0
   Sprayed Strokes 13.0
   Stained Glass 13.0
   Stamp 13.0
   Standard Deviation 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Sumi-e 13.0
   Summation 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Targa 13.0
   Texturizer 13.0
   Tiles 13.0
   Torn Edges 13.0
   Twirl 13.0
   U3D 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Underpainting 13.0
   Vanishing Point 13.0
   Variance 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Variations 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Water Paper 13.0
   Watercolor 13.0
   Wave 13.0
   Wavefront|OBJ 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   WIA Support 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   Wind 13.0
   Wireless Bitmap 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00)
   ZigZag 13.0
Optional and third party plug-ins: NONE
Plug-ins that failed to load: NONE
Flash:
   Mini Bridge
   Kuler
Installed TWAIN devices: NONE
If anyone wants the source images let me know and I'll upload them somewhere, though that process will take a couple of days because they're not small.
  • PECourtejoie
    Jan 11, 2006
    Mar 30, 2012 5:56 AM   in reply to Martin Klefas
    Hello, welcome to the beta forum. Sorry to hear you run into problems, but it is the goal of the beta to catch them.
    I want to commend you for your excellent report! One small detail: how many files are you combining for the HDR? Does it crash if you use less of them? (I.E. is there a file size/number that triggers the issue?)
  • PECourtejoie
    Jan 11, 2006
    Mar 30, 2012 7:15 AM   in reply to Martin Klefas
    Do you think you could try before going to bed, or something like that? Finding the treshold might be useful for the team to reproduce the issue.
    Mar 30, 2012 11:26 AM   in reply to Martin Klefas
    Hi Martin,
    I've sent you a private message with some things to investigate.
    We can post the solution here when we get it all figured out.
    Meredith
    Apr 2, 2012 10:41 AM   in reply to Martin Klefas
    Hi Martin,
    Per my private message, the "uncaught JavaScript" exception is something we've seen and have yet to determine a cause or solution.
    Would you please try the following.
    • Do you have following Preferences > Interface settings ON? If they're OFF, does it work if you turn them on?
       - Open Documents as Tabs
       - Enable Floating Document Window Docking
    • Does Merge to HDR work for you at all with smaller files (such as those in the sample set inside the application folder for CS5)?
    • Do other scripts work for you, specifically...
       - File > Scripts > Load Files into Stack... ?
       - File > Automate > Photomerge...?
    • Have you tried restarting with deleted preferences? http://help.adobe.com/en_US/photoshop/cs/using/WSfd1234e1c4b69f30ea53e 41001031ab64-74aaa.html
    The HDR screen image preview going black is a known issue related to low-system memory conditions that we have been working on a solution for.
    In the meantime, the workaround would be to lower Photoshop's memory usage from your current (72%) down to as low as (50%).
    Purging memory may help: http://help.adobe.com/en_US/photoshop/cs/using/WSfd1234e1c4b69f30ea53e 41001031ab64-748aa.html
    What was the "entirely new error message"? And is the  Uncaught Exception  the "standard" message?
    Thank,
    Meredith
