I am trying to do a parallel Bible layout of 3 different translations and need the verses to line up with each other from the 3 different versions. For example, when you would look at verse 3 in a specifice chapter, the top of that verse would line up in all three versions (columns). How can I do this???
I'm also doing page layout of documents with parallel (multilingual) columns, and I think it would be great if InDesign could handle this. I would save so much time! The table solution is not working for me, because I would have to manually break paragraphs at the bottom of each page. Plus, my client is updating the documents each quarter. So manually split tables will have to be fixed all along the document, again and again.
A long time ago, I've suggested this feature through "Feature Request" form. I wish InDesign could do this, just like WordPerfect of Word... ![]()
You can have parallel threads -- you need to create master text frames and link them in two threads -- it's the paragraph synchronization that's the problem. One, really ugly and time consuming, method of dealing with this would be to set your style to have the first line align to a grid, then run through the document and add additional space before or after paragraphs to push the first lines onto the same grid line.
