j.keil
Bug? Zooming out via key shortcut won't stop when zooming out (Mac OS 10.7.3)
Mar 30, 2012 1:44 AM
Hey,
while I created a new document, I started to zoom in/out particular areas of the images using the key shortkuts <space>+<cmd> for zooming in and <space>+<cmd>+<alt> for zooming out of an area.
While this works fine in my Photoshop CS5, it troubbles in CS6:
Once I want to zoom out (via <space>+<cmd>+<alt> and a left-mouseclick), the zooming won't stop until it reached the smallest zoom level, instead of zooming out just a step. It however works, while I zoom in (via <space>+<cmd> and a left-mouseclick).
I'm so used to this shortcut since a cupple of versions now (it also works in other programms as well) and it is realy annoying.
It also happens that when I press <space> and another key (e.g. to zoom in/out) that Photoshop CS6 does sometimes not release the hand-tool, that I use to move the canvas via holing <space> and left-mouse down. Pressing <space> again solve this. However, I would exspect the hand-/move-tool only to work while <space> is pressed.
Thanks.
System Infos from Photoshop:
Adobe Photoshop Version: 13.0 (13.0 20120305.m.415 2012/03/05:21:00:00) x64
Operating System: Mac OS 10.7.3
System architecture: Intel CPU Family:6, Model:23, Stepping:10 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1
Physical processor count: 2
Processor speed: 2660 MHz
Built-in memory: 4096 MB
Free memory: 1919 MB
Memory available to Photoshop: 3461 MB
Memory used by Photoshop: 70 %
Image tile size: 128K
Image cache levels: 4
OpenGL Drawing: Enabled.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Version: 2.1 NVIDIA-7.18.11
OpenCL Unavailable
Video Card Vendor: NVIDIA Corporation
Video Card Renderer: NVIDIA GeForce 9600M GT OpenGL Engine
Display: 2
Display Depth:= 32
Display Bounds:=  top: 0, left: -1440, bottom: 900, right: 0
Video Renderer ID: 16918028
Video Card Memory: 214 MB
Video Rect Texture Size: 8192
OpenCL Unavailable
Display: 1
Main Display
Display Depth:= 32
Display Bounds:=  top: 0, left: 0, bottom: 1200, right: 1920
Serial number: Tryout Version
Application folder: Macintosh HD:Applications:Adobe Photoshop CS6:
Photoshop scratch has async I/O enabled
Scratch volume(s):
  Macintosh HD, 297.3G, 27.0G free
Required Plug-ins folder: Macintosh HD:Applications:Adobe Photoshop CS6:Adobe Photoshop CS6.app:Contents:Required:
Primary Plug-ins folder: Macintosh HD:Applications:Adobe Photoshop CS6:Plug-ins:
Additional Plug-ins folder: not set
Installed components:
   adbeape.framework   adbeape   3.3.8.19346   66.1025012
   AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.2.29.18602   66.490082
   adobe_caps.framework   adobe_caps   5.0.11.0   1.256674
   AdobeACE.framework   AdobeACE   2.19.18.19243   66.492997
   AdobeAGM.framework   AdobeAGM   4.26.17.19243   66.492997
   AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
   AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
   AdobeBIB.framework   AdobeBIB   1.2.02.19243   66.492997
   AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   66.492997
   AdobeCoolType.framework   AdobeCoolType   5.10.31.19243   66.492997
   AdobeCrashReporter.framework   AdobeCrashReporter   6.0.20120201
   AdobeExtendScript.framework   AdobeExtendScript   4.2.12.18602   66.490082
   AdobeJP2K.framework   AdobeJP2K   2.0.0.18562   66.236923
   AdobeLinguistic.framework      17206
   AdobeMPS.framework   AdobeMPS   5.8.0.19463   66.495174
   AdobeOwl.framework   AdobeOwl   4.0.93   66.496052
   AdobePDFL.framework   AdobePDFL   10.0.1.18562   66.419471
   AdobePDFSettings.framework   AdobePDFSettings   1.4
   AdobePIP.framework   AdobePIP   6.0.0.1642
   AdobeScCore.framework   AdobeScCore   4.2.12.18602   66.490082
   AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
   AdobeXMP.framework   AdobeXMPCore   66.145661   66.145661
   AdobeXMPFiles.framework   AdobeXMPFiles   66.145661   66.145661
   AdobeXMPScript.framework   AdobeXMPScript   66.145661   66.145661
   ahclient.framework   ahclient   1.7.0.56
   aif_core.framework   AdobeAIF   3.0.00   62.490293
   aif_ocl.framework   AdobeAIF   3.0.00   62.490293
   aif_ogl.framework   AdobeAIF   3.0.00   62.490293
   AlignmentLib.framework   xcode   1.0.0.1
   amtlib.framework   amtlib   6.0.0.75
   boost_date_time.framework   boost_date_time   6.0.0.0
   boost_signals.framework   boost_signals   6.0.0.0
   boost_system.framework   boost_system   6.0.0.0
   boost_threads.framework   boost_threads   6.0.0.0
   Cg.framework   NVIDIA Cg
   CIT.framework   CIT   2.0.5.19287   145486
   data_flow.framework   AdobeAIF   3.0.00   62.490293
   dvaaudiodevice.framework   dvaaudiodevice   6.0.0.0
   dvacore.framework   dvacore   6.0.0.0
   dvamarshal.framework   dvamarshal   6.0.0.0
   dvamediatypes.framework   dvamediatypes   6.0.0.0
   dvaplayer.framework   dvaplayer   6.0.0.0
   dvatransport.framework   dvatransport   6.0.0.0
   dvaunittesting.framework   dvaunittesting   6.0.0.0
   dynamiclink.framework   dynamiclink   6.0.0.0
   FileInfo.framework   FileInfo   66.145433   66.145433
   filter_graph.framework   AdobeAIF   3.0.00   62.490293
   hydra_filters.framework   AdobeAIF   3.0.00   62.490293
   ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
   ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
   image_compiler.framework   AdobeAIF   3.0.00   62.490293
   image_flow.framework   AdobeAIF   3.0.00   62.490293
   image_runtime.framework   AdobeAIF   3.0.00   62.490293
   LogSession.framework   LogSession   2.1.2.1640
   mediacoreif.framework   mediacoreif   6.0.0.0
   PlugPlug.framework   PlugPlug   3.0.0.383
   UpdaterNotifications.framework   UpdaterNotifications   6.0.0.24   "6.0.0.24"
   wrservices.framework
Required plug-ins:
   3D Studio 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
   Accented Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Adaptive Wide Angle 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
   ADM 3.10x16, Copyright © 1987-2008 Adobe Systems Inc.  All rights reserved. - from the file “AdobeADM.bundle”
   Angled Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Average 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Average.plugin”
   Bas Relief 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Camera Raw 7.0 (308), Copyright © 2012 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
   Chalk & Charcoal 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Chrome 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Cineon 13.0 20120305.m.415 2012/03/05:21:00:00  ©2002-2012 Adobe Systems Incorporated - from the file “Cineon.plugin”
   Clouds 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
   Collada DAE 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
   Color Halftone 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Colored Pencil 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Conté Crayon 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Craquelure 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Crop and Straighten Photos 13.0 20120305.m.415 2012/03/05:21:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
   Crop and Straighten Photos Filter 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Crosshatch 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Crystallize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Cutout 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Dark Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   De-Interlace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Dicom 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “dicom.plugin”
   Difference Clouds 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
   Diffuse Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Displace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Dry Brush 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Eazel Acquire 13.0 20120305.m.415 2012/03/05:21:00:00  ©1997-2012 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
   Embed Watermark NO VERSION - from the file “DigiSign.plugin”
   Enable Async I/O 13.0 20120305.m.415 2012/03/05:21:00:00  © 2004-2012 Adobe Systems Incorporated - from the file “Enable Async IO.plugin”
   Entropy 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
   Extrude 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   FastCore Routines 13.0 20120305.m.415 2012/03/05:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “FastCore.plugin”
   Fibers 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Film Grain 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Filter Gallery 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Flash 3D 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
   Fresco 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Glowing Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Google Earth 4 KMZ 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
   Graphic Pen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Halftone Pattern 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   HDRMergeUI 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
   IFF Format 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Ink Outlines 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   JPEG 2000 13.0 20120305.m.415 2012/03/05:21:00:00  ©2001-2012 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
   Kurtosis 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
   Lens Blur 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
   Lens Correction 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
   Lens Flare 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Liquify 13.0, Copyright © 2001-2012 Adobe Systems Incorporated - from the file “Liquify.plugin”
   Matlab Operation 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
   Maximum 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
   Mean 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
   Measurement Core 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
   Median 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
   Mezzotint 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Minimum 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
   MMXCore Routines 13.0 20120305.m.415 2012/03/05:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “MMXCore.plugin”
   Mosaic Tiles 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Multiprocessor Support 13.0 20120305.m.415 2012/03/05:21:00:00  ©1990-2012 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
   Neon Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Note Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   NTSC Colors 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
   Ocean Ripple 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Oil Paint 13.0, Copyright © 2011 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
   OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Paint Daubs 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Palette Knife 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Patchwork 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Paths to Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   PCX 13.0 20120305.m.415 2012/03/05:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PCX.plugin”
   Photocopy 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Photoshop 3D Engine 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
   Picture Package Filter 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
   Pinch 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Pixar 13.0 20120305.m.415 2012/03/05:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “Pixar.plugin”
   Plaster 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Plastic Wrap 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Pointillize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Polar Coordinates 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Portable Bit Map 13.0 20120305.m.415 2012/03/05:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “PBM.plugin”
   Poster Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Radial Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Radiance 13.0 20120305.m.415 2012/03/05:21:00:00  ©2003-2012 Adobe Systems Incorporated - from the file “Radiance.plugin”
   Range 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
   Read Watermark NO VERSION - from the file “DigiRead.plugin”
   Reticulation 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Ripple 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Rough Pastels 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Save for Web 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - from the file “Save for Web.plugin”
   ScriptingSupport 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
   Shear 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Skewness 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
   Smart Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Smudge Stick 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Solarize 13.0 20120305.m.415 2012/03/05:21:00:00  ©1993-2012 Adobe Systems Incorporated - from the file “Solarize.plugin”
   Spatter 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Spherize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Sponge 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Sprayed Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Stained Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Stamp 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Standard Deviation 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
   Sumi-e 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Summation 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
   Targa 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Texturizer 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Tiles 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Torn Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Twirl 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   U3D 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
   Underpainting 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Vanishing Point 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
   Variance 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
   Water Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Watercolor 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
   Wave 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Wavefront|OBJ 13.0 20120305.m.415 2012/03/05:21:00:00  ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
   Wind 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
   Wireless Bitmap 13.0 20120305.m.415 2012/03/05:21:00:00  ©1989-2012 Adobe Systems Incorporated - from the file “WBMP.plugin”
   ZigZag 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Optional and third party plug-ins: NONE
Plug-ins that failed to load: NONE
Flash:
   Mini Bridge
   Kuler
Installed TWAIN devices: NONE
  • Pierre Courtejoie
    Jan 11, 2006
    Mar 30, 2012 6:33 AM   in reply to j.keil
    Hi welcome to the beta!
    I'll have several questions: when you hit the spacebar in a text document, does it sometimes create several spaces? What if you use ALT+Spacebar?
    Do you run into the issue in Photoshop it the case when you use <CMD>+< - > ?
    Did you try to reset the zoom tool (Right-click on the magnifier icon on the option bar?)
    Do you have a key repeater function activated in the OS (accessibility?)?
    If you never use the animated zoom, you can disable it in Photoshop>preferences>general>animated zoom.
    Apr 2, 2012 5:38 PM   in reply to j.keil
    You have quite a few options when you zoom. Here are some.
    If you click and hold, the scrubby animated zoom will slowly zoom the image in. You will need to let go of the mouse click at around the time that it's Almost to the zoom level you're after, since when you release the mouse button, both in zooming IN and zooming OUT there is a bit of an exta second to the animation while the momentum slows. This isn't the fastest way to zoom in or out, but is a nice smooth method of accomplishing the zoom.
    If you cmd-spacebar and drag left and right, you will get the scrubby zoom function where you can zoom in and out of your image by dragging the mouse cursor side to side.
  • Pierre Courtejoie
    Jan 11, 2006
    Apr 5, 2012 4:06 AM   in reply to j.keil
    Also, are you using a wacom tablet?
