I'm in charge of developing a video recorder in as3 (http://hdfvr.com) and the video recorder has been working fine for the past 2 years however with the latest FP update (11.2) it has stopped working because these 3 NetStream events are never triggered anymore:
HDFVR.netStatusHandler(NetStream.Buffer.Empty) _state=uploading
HDFVR.netStatusHandler(NetStream.Record.Stop) _state=idle
HDFVR.netStatusHandler(NetStream.Unpublish.Success) _state=idle
This happens regardless of the media server used (Red5/FMIS/Wowza)
I have posted this issue in the Adobe Flash Player Bug Database:
https://bugbase.adobe.com/index.cfm?event=bug&id=3154124
I have also informed my clients and they're waiting for a fix, unfortunately I am not sure I can do a workaround without those NetStream events.
You'll probably be better off posting in one of the Pro (sub)forums here: http://forums.adobe.com/community/flash
We believe this is now fixed with Flash Player 11.3 Beta 2 which was released yesterday. Could you give this a shot and let us know how it works for you?
Chris
I've report the same problem using Flash Player 11.2.
From test that performed using Flash Player 11.3 beta 3 the issue seems to be solved, so I can handle NetStream.Buffer.Empty event correctly.
I'd like to ask your suggestion how is possibile workaround this problem until Flash Player 11.3 is not release as stable version.
Some users that use automatic update has Flash Player update to last stable release (11.2), I'd like to ask you suggestion how to correct manage this case.
I'd like to introduce some modification in the code for handle this case for example start a timer and monitor how many data are present in buffer, and when buffer is empty, use same function that should be called when NetStream.Buffer.Empty event is raised?
I'd kindly like to ask if you can give to me some suggestion.
Thank you very much
Maurizio
