I need to red stroke fields. Inspite of the doc and this great thread : http://forums.adobe.com/message/4215908#4215908,
I can't get it working ![]()
field.onDraw = function()
var gx = this.graphics,
pen = this.graphics.newPen (this.graphics.PenType.SOLID_COLOR, [1, 0, 0,1], 5);
gx.drawOSControl();
gx.rectPath( this.location[0] , this.location[1], this.size.width, this.size.height);
gx.strokePath(pen);
What am I doing wrong ?
Best,
Loic
I finally got what I wanted with a workaround. First of all I could get the above snippet adding this line :
gx.drawOSControl();
gx.newPath();
gx.strokePath(pen);
But the result wasn't the one I expected. The path was indeed drawn inside the text field area when I wanted it outside. Finally my cheat was to create a dummy group object on the back of the text field. Those both objects are placed into a stacked group. Then it's easy to set dimensions and background attributes for the dummy group and finally get what I wanted.
var w = new Window('dialog');
var gp = w.add('group');
gp.orientation = 'stack';
gp.alignChildren = ['center','center'];
var dummyGp = gp.add('group');
dummyGp.preferredSize = [102,52];
dummyGp.graphics.backgroundColor = dummyGp.graphics.newBrush (dummyGp.graphics.BrushType.SOLID_COLOR, [1,0,0,1] );
var tf1 = gp.add('edittext');
tf1.preferredSize = [100,50];
w.show();
Hope it helps.
Loic
Hi Peter, Marc,
Sorry for the delay, I haven't been warned of your posts and almost seen them by surprise.
@Peter, that's the nasty one. The environment should be 100% macs but that's not a reason.
@Marc, I thought margins deal with spacing inside the items. I gave it a try and the margin itself look much wider than requested ![]()
If I set margins = 1, I should expect 1 px wide stroke. But it looks like it's three added :?
Loic
Hi Loïc,
Yes, it's a Mac thing. On Mac OS, the EditText widget is subject to a specific focus ring wich automatically allocates 2 or 3 additional transparent pixels all around the field! Hence, if the control is nested within a background-colored group, that color is revealed through this additional space.
From that point you need to apply two fixes:
(1) create a white subgroup between the outer group and the EditText to make sure that the revealed background fits the EditText background;
(2) make the EditText borderless to inhibits its own stroke.
Now to the code:
// ScriptUI EditText with custom border (Win & Mac)
var STROKE_COLOR = [1,0,0], // red
STROKE_WEIGHT = 1, // in pixels
FILL_COLOR = [1,1,1], // white
INSET_SPACE = 3; // in pixels -- Mac OS focus ring needs it >=3
var u,
w = new Window('dialog'),
gBorder = w.add('panel').add('group'),
gSpacer = gBorder.add('group'),
e = gSpacer.add('edittext', u, u, {borderless:true}),
bCancel = w.add('button', u, "Cancel"),
gx = w.graphics,
SOLID_BRUSH = gx.BrushType.SOLID_COLOR;
// Edit field settings
e.characters = 12;
gBorder.margins = STROKE_WEIGHT;
gBorder.graphics.backgroundColor = gx.newBrush(SOLID_BRUSH, STROKE_COLOR );
gSpacer.margins = INSET_SPACE;
gSpacer.graphics.backgroundColor = e.graphics.backgroundColor = gx.newBrush(SOLID_BRUSH, FILL_COLOR );
w.show();
Hope that works.
Marc
