Dropdown with Picture?
Mar 29, 2012 9:44 AM
Hi all,
Anybody know how can we do dropdown menu with picture
Please help this
Thanks in advance
Manoj
    Mar 29, 2012 10:06 AM   in reply to manojb05
    Same way you would make a regular CSS dropdown, just replace the text between the <li></li> tags with image code.  If that's not what you have you will need to post a link to the page with the menu you are using.
    Mar 30, 2012 2:52 AM   in reply to manojb05
    http://www.webdesigndev.com/web-development/create-the-fanciest-dropdo wn-menu-you-ever-saw#fancyimages
    There's a tutorial page for a fancy drop-down with images.  If you are not used to working with code, it might be a little overwhelming but, I don't think it is so complicated after a quick look myself.
    The principle in that idea is to set the images as background image using the CSS.
    You don't say whether you want the whole menu item to be an image instead of text (not such a good idea in my mind) or whether you want to use images to add to the design as in the example.  Either way, you might be able to work it out from that example.
    Martin
    Mar 30, 2012 10:55 AM   in reply to manojb05
    Well, I havenever done that myself but I think you need to Google "mega menu  jquery".  That might get you somewhere.
    Martin
