Flash Player crashes constantly in Firefox, IE and Chrome
Mar 20, 2012 11:20 AM
  Latest reply: royal3322, Mar 9, 2013 10:58 AM
Replies 1 2 3 Previous Next
    Mar 30, 2012 11:21 AM   in reply to Chris Campbell
    Dear Chris: I filed a bug report with .dmp.zip attached. It was not letting me attach the .dmp unless I zipped it. Now my question is: Should I file a new bug report for every crash or keep attaching the .dmp file to the same bug report? I have something like 5 crashes per day (i.e., every time I play a video).
    --Thaks for your help
    -gajananam
  • Chris Campbell
    May 4, 2010
    Mar 30, 2012 11:28 AM   in reply to Gajananam
    I'd attach a few more crash dumps to the same bug report.  Then we can tell if these are all the same issue.  No need to add each one you get unless we discover that we're seeing different problems.
    Can you post back with the bug number so I can take a look?
    Thank you for taking the time to do this!
    Chris
    Mar 30, 2012 12:06 PM   in reply to Chris Campbell
    Dear Chris: The bug report no. is 3153472, filed under my login gajananam.
    What fiexes are there in the new version 11.2.202.228? Should I update mine an start using it?
    --Cheers
    --gajananam
  • Chris Campbell
    May 4, 2010
    Mar 30, 2012 12:10 PM   in reply to Gajananam
    I would definitely recommend updating to the newest version.  There's a large number of bug fixes and some great new features included.
    Apr 1, 2012 10:23 AM   in reply to Chris Campbell
    Dear Chris: After updating to 11.2.202.228, I still have crashes on every video. Please see bug re4port no. 3154705 with .dmp attached. Sometimes instead of BSODing, IE8 closes with the following error.
    problem signature:
    Problem Event Name: APPCRASH
    Application Name: iexplore.exe
    Application Version: 8.0.7601.17514
    Application Timestamp: 4ce79912
    Fault Module Name: Flash32_11_2_202_228.ocx
    Fault Module Version: 11.2.202.228
    Fault Module Timestamp: 4f6278e1
    Exception Code: c0000005
    Exception Offset: 0018da74
    OS Version: 6.1.7601.2.1.0.768.3
    Locale ID: 1033
    Additional Information 1: 0a9e
    Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
    Additional Information 3: 0a9e
    Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
    --Please Help
    --gajananam
  • Chris Campbell
    May 4, 2010
    Apr 2, 2012 2:39 PM   in reply to Gajananam
    gajananam,
    Based off the BSOD errors you mentioned a few posts up, I'm wondering if you are encountering a memory issue.  Could you try running the Windows Memory Diagnostic (type "memory" in the start bar's search field) and memtest86 to verify all of your memory is valid?
    Could you also provide us with a copy of your dxdiag report?
    Chris
    Apr 5, 2012 10:31 AM   in reply to Chris Campbell
    Dear Chris: I ran the system memory diagnostics and every thing seems ok. My system does not have memtest86. Shoud I download it from microsoft web site and run it? Also, is dxdiag the output of memtest86?
    --cheers
    --ram
  • Chris Campbell
    May 4, 2010
    Apr 5, 2012 10:34 AM   in reply to Gajananam
    Dxdiag is a microsoft utility built into Windows.  From what I've read, memtest86 is one of the defacto memory testers and should definitely rule out corrupt memory as a possibility.
    Apr 5, 2012 10:43 AM   in reply to Chris Campbell
    Dear Chris: Ok, When I hit F9 on bootup, it runs a detailed memory diagnostics, I guess this is memtest86. This showed no issues. Let me run dxdiag and send you the output.
    --cheers
    --gajananam
  • Chris Campbell
    May 4, 2010
    Apr 5, 2012 10:49 AM   in reply to Gajananam
    Thank you for trying that.  Could you attach the dxdiag to your bug report?  In addition, you might want to comment in the bug report that you've tested your memory for hardware problems but it came back clean.
    Apr 9, 2012 10:24 AM   in reply to Chris Campbell
    Dear Chris: I have attached, to bug report no. 3154705, i)dxDiag report and ii) new dump file.
    Also added a note on memory diagnostics coming up clean. This is per your request.
    Gambit, in another thread, fixed the issue by replacing his realtek audio card. Should I now try that approach, or you may find a workaround for me?
    --cheers
    --gajananam
  • Chris Campbell
    May 4, 2010
    Apr 9, 2012 11:22 AM   in reply to Gajananam
    Thanks Gajananam
    Apr 9, 2012 11:36 AM   in reply to android2112
    I've noticed this happening since the last update to Flash Player. This only happens on one of my PCs, not on all of them. I'm running the DirectX Debug Runtimes, which give the following output when running the plugin from Firefox:
    [3280] Direct3D9: :====> ENTER: DLLMAIN(6830d9a0): Process Attach: 00000cd0, tid=000012e4
    [3280] Direct3D9: :====> EXIT: DLLMAIN(6830d9a0): Process Attach: 00000cd0
    [3280] Direct3D9: (INFO) :Direct3D9 Debug Runtime selected.
    [3280] Direct3D9: (INFO) :======================= Hal HWVP device selected
    [3280] Direct3D9: (INFO) :HalDevice Driver Style b
    [3280] Direct3D9: :DoneExclusiveMode
    [3280] Direct3D9: (INFO) :Using FF to VS converter
    [3280] Direct3D9: (INFO) :Using FF to PS converter
    [3280] Direct3D9: (INFO) :Enabling multi-processor optimizations
    [3280] Direct3D9: (INFO) :DDI threading started
    [3280] Direct3D9: (ERROR) :Final Release for a device can only be called from the thread that the device was created from.
    When accessing the same page from Internet Explorer, this brings down the entire iexplore process (And there's no debug output through DebugView available).
    Looks like the new version of flash player is invoking undefined behaviour?
  • Chris Campbell
    May 4, 2010
    Apr 9, 2012 3:16 PM   in reply to Evil_Steve
    Hi Steve,
    Would you be willing to open a new bug report on this over at bugbase.adobe.com?  We'll want a .dmp (from the IE crash) or Firefox crash ID if possible, along with a dxdiag report and steps to repro.  Do you know if this crash also occurs with the release directx runtime?
    Apr 10, 2012 12:21 PM   in reply to Chris Campbell
    Hi Chris,
    I've added bug #3162242 as requested.
    Cheers,
    Steve
  • Chris Campbell
    May 4, 2010
    Apr 10, 2012 12:34 PM   in reply to Evil_Steve
    Thank you Steve.
    Apr 15, 2012 1:53 PM   in reply to Chris Campbell
    Dear Chris: The new release 11.2.202.233 also BSODs after 12 mins. Pleaes see the bug report no. 3166127. The dump file is attached.
    Does Adobe normally release a new version 2nd Fri. of every month? Shall I wait till May to test try again?
    --Cheers
    --gajananam
  • Chris Campbell
    May 4, 2010
    Apr 20, 2012 5:10 PM   in reply to Gajananam
    We've got a new 11.3 beta 2 release that was made yesterday.  You might want to give that a try.  I'm going to contact Zhe and see what other blue screen bug he's referring too in your bug report.
    Apr 20, 2012 7:30 PM   in reply to Chris Campbell
    Dear Chris: I would like to try the 11.3 beta. Where do I download it from?
    --gajananam
  • Chris Campbell
    May 4, 2010
    Apr 22, 2012 6:14 AM   in reply to Chris Campbell
    Hi Chris,
    The v11.3 plugin for Firefox still crashes - although this time without any debug output from DebugView. Previously I would just get the FlashPlayer control showing "The Adobe Flash plugin has crashed. Send crash report", whereas now I get the standard Windows Problems and Solutions dialog opening with "Adobe Flash Player 11.3 r300 has stopped working" and then the "The Adobe Flash plugin has crashed. Send crash report" message.
    As before, the Release Direct3D runtimes do not show the problem. I've added a note to the bug report with this information.
    Jun 9, 2012 8:48 AM   in reply to Evil_Steve
    Since version 11.2.202.18(was beta version) and the flash plugin crashes all browsers on my PC. whether the normal netscape dll or the IE ocx, testing with several webkit and gecko ones; the result is always the same KABOOM. It's obvious something has gone haywire with Adobe devs, precisely since the release of 2 versions (32 and 64bits). I've been trying with different versions and it appears only those releases with 2 editions have the problem; anything before those releases work perfectly fine, so please don't insult our intelligence with check your drivers etc and start cleaning up your mess, personally I've given up on future flash player plugins and I hope HTML5 kicks in faster especially in vid sites so we can get over this endless codswallop.
    XP SP2
    P.S. before telling me to check your antivirus and your hardware accel.; I'm a programmer I don't even have an antivirus, please don't tread there
    P.S.S I have arelatively old macbook with OSX 10.5.2 that I rarely used, just tested latest bollocks 11.3.xxx and same thing happens. When 2 completely different platforms suffer the exact problem from a plugin; then it doesn't take a lot of analytical thinking to know where the problem lies(glug glug)
  • Chris Campbell
    May 4, 2010
    Jun 9, 2012 4:28 PM   in reply to KiloMkII
    Hi Orazio,
    As a programmer, I'm sure you're aware of the importance of reproducible steps.  If you'd like to see your issues addressed, please open a bug report at bugbase.adobe.com.  Include steps and system specifics required for us to reproduce this problem internally.  In addition, any crash dumps/logs you have would be helpful.  Here's a FAQ that describes in detail the information we'd like:
    How do I report a Flash Player crash to Adobe?
    Without these details and if we are unable to reproduce a crash internally, the likelyhood of it being fixed is reduced drastically.
    Jun 10, 2012 11:41 AM   in reply to Chris Campbell
    Hello, and to everyone having this problem:
    Try this
    - In Chrome type about:plugins
    - Click the + next to details in the top right corner
    - scroll down to flash player and disable all of them except Pepper Flash version 11.2.31.144 (you may have 1 or 2 others.) Here's what it looks likeDisablingFlash.jpg
    I'm not sure how to do this in Firefox. Also, this may not fix everyones problems, however it worked for me so I thought I'd spread the word.
    Jun 24, 2012 1:08 PM   in reply to android2112
    Having the exact same issue on my Windows 7 64Bit laptop.  Started happening a few weeks ago.
    Every single time I load my browser (Whether it is Chrome, Firefox, IE) I have my favorites set to boot up on each one, some of them have flash and as soon as the browser loads, Flash crashes.
    So very very frustrated right now.
    I uninstall flash, reboot, reinstall, load browser, crash.
    Any updates on the crashes for Flash?  Is there anything I can do to get help on this from Adobe?
    TIA,
    Whiteice
    Jun 24, 2012 1:42 PM   in reply to Whiteicedmstech
    Don’t count on help from Adobe. I never heard anything from them. Good luck!
    Jul 31, 2012 7:20 AM   in reply to sniderrick3
    I have a miserable time with Flash as well. It crashes daily on my kids Vista machine, but last week I got a brand new Dell E6530 Windows 7 64. This machine is spanking new and has only Office and the main browsers on it, and Adobe X Standard. Flash crashes like crazy. I am on 11.3.300.268. Crashes like mad in FF, and to a lesser degree everywhere else. Funny thing is it also crashes on my Mac Book Air 2011, though not very often. These computers are brand new, unmolested, as delivered by Dell and Mac.
    Geesh, even if it is going to crash a lot, can you make it crash quickly rather than hang my browsers for 2 minutes everytime? At least it does not crash the browsers - they seem to recover to the Flash Crashed image just fine. I have a BSCs and have been writing code for 17 years - unhandled exceptions usually happen very quickly unless there is a stack overflow, race, or infinite loop.
    Jul 31, 2012 8:31 AM   in reply to NikonD700User55
    I cannot say how angry I am that Adobe has screwed up my computer. I used to have a system on which I could watch Channel 4OD videos an hour long on firefox without a single holdup. Since attempting to upgrade Flash (after being prompted to do so on Youtube) I now I have to refresh every three minutes. I can't even get through a five minute Youtube video without it freezing. Flash version 11.3 didn't work at all and now version 10.3 runs as I described above. To find out by researching on the internet that Adobe KNEW that there were problems and still didn't warn me on the update page makes me incredibly angry.
    How about a warning on the update page in letters an inch high
    "WARNING, USING THIS UPDATE MIGHT SCREW UP YOUR COMPUTER AND WE HAVEN'T GOT A CLUE HOW TO FIX IT!!"
    Too late to get me back to a useable system but at least it might help others.
    Jul 31, 2012 11:13 AM   in reply to Schneiderman93
    Dear Schneiderman93: How do I download pepper flash? I have a windows 7 64-bit machine, and about:plugins only shows shockwave flash and nothing else. Shockwave flash, of course, crashes ad infinitum.
    --regards
    --gajananam
  • Chris Campbell
    May 4, 2010
    Jul 31, 2012 7:30 PM   in reply to Gajananam
    For those encountering problems, I apologize.  I'd recommend rolling back to a previous version if the latest update hasn't resolved your problems.
    How do I revert to a previous version of Flash Player?
    Chris
    Aug 2, 2012 9:06 AM   in reply to Chris Campbell
    Hey Chris, using pepper flash does help some (disable all other flash add ons). YOU have been great to try and find solutions. Thank you! Is Adobe not going to work on a fix to this problem? Doesn’t say much for the company. Anyway, thanks for your support!
    Aug 2, 2012 9:30 AM   in reply to sniderrick3
    Dear Sniderrickk3: Where can I find this pepper flash? does it run on windows? Would like to try this.
    --regards
    --gajananam
    Aug 2, 2012 10:16 AM   in reply to Gajananam
    Try this
    - In Chrome type “about:plugins” in the address bar (instead of www.)
    - scroll down to flash player and disable all of them except Pepper Flash (may be shortened to pep)  version 11.2.31.144 (you may have 1 or 2 others.) Here's what it looks like
    Aug 2, 2012 10:17 AM   in reply to Gajananam
    Gajananam, if the last reply didn’t make sense, click on “view the complete discusssion” and scroll up till you find the post. good luck
    Aug 2, 2012 11:12 AM   in reply to sniderrick3
    Dear Sniderrick3: Thanks; Mysteriously, I am able to find the "pepper flash" in my windows xp chrome, but not in my win 7 chrome at home. I was searching for this in Windows 7 in chrome. It said my Chrome is up-to-date but I cound not locate pepper flash. Will try again tonight.
    Does pepper flash completely solve the problem of crashes or just helps a little?
    --Thanks again for your help
    --gajananam
    Aug 2, 2012 11:16 AM   in reply to Gajananam
    just helps some. Adobe doesn’t seem to want to fix the bugs in their flash program!
  • Chris Campbell
    May 4, 2010
    Aug 2, 2012 4:32 PM   in reply to sniderrick3
    We definitely want to find and fix these crashes!  Any crash logs you can submit will help, or if you have reproducible steps I encourage you to take a minute and open a bug at bugbase.adobe.com.
    @gajananam - you might want to see if you have an update for Chrome available on your Win7 system.  I had to check mine, which prompted an update that allowed me to get the pepper build.
    Aug 27, 2012 3:00 PM   in reply to Chris Campbell
    I'll put my 2 cents in. I've experienced these plugin lock-ups ever since a flash player patch over half a year ago. I can't remember any time flash had crashed prior to this.  I keep firefox, IE and the flash player up to date, constantly hoping these crashes will cease.
    One thing to note for myself is that the plugin doesnt crash on its own exactly, sometimes the audio goes (which somehow disables all of my audio), sometimes video will simply not load. It seems to be related to leaving the plugin active too long (my workstation is on almost 24/7). The short-term fix is usually to manually end the application in task manager, then restart the webpage. It may be conflicting with my drivers or my browser. I've tried updating both to no avail. My other systems with the same updates seem to have similar symptoms.
    Sep 5, 2012 2:32 PM   in reply to bdave111
    My answer as of right now is to disable Adobe Flash in Firefox.
    With respect, you do not seem to have gotten it right for many months. This latest update is the worst of the worst. Firefox is almost unusable for any page that has Flash on it with this plugin enabled. The Flash seems to restart and restart every second or so and I'm constantly clicking.
    So, no thank you, Adobe. Perhaps HTML 5 standard will become more universal and make this buggy, crash-prone, resource-hogging, irritating piece of software obsolete.
    Alan Stancliff
  • Chris Campbell
    May 4, 2010
    Sep 5, 2012 10:01 PM   in reply to AlanStancliff02
    @AlanStancliff02 - Did you try disabling Flash Player's Protected Mode (see the bottom of the FAQ linked below) to see if that helped in your case?
    I'm sorry you're running into this, but having looked at the crash and hang statistics on Mozilla's crash stats site, the latest version of Flash Player appears to be more stable than the last (and MUCH better than the initial 11.3 release.)  We've still got issues that we're working on and we really depend on users like yourself that run into problems for information and bug reports.
    How do I troubleshoot Flash Player's protected mode for Firefox?
Actions
