Flash player crashing my computer.
Mar 30, 2012 10:56 AM
I am running 64 bit windows 7 and am trying to install Adobe Flash Player 11.2.202.228.  After installing, my computer will run for upwards of 20 minutes before it either freezes or I get the blue memory dump screen and I have to power it down.  Only uninstalling stops this from happening.  I am using Firefox 11.  Please help.
  • Chris Campbell
    May 4, 2010
    Mar 30, 2012 11:08 AM   in reply to skrobbs
    Hi skrobbs,
    Sorry you're going through this.  What type of things are you doing when your system crashes?  If you're watching video, can you try updating your video drivers to the latest version to see if that resolves the problem?
    Chris
  • Chris Campbell
    May 4, 2010
    Mar 30, 2012 12:09 PM   in reply to skrobbs
    Could you see if it occurs without specifically using flash?  It might be easiest to do this by disabling this plugin in Firefox.
    Can you also check your Event Viewer to see if you have any errors that might correspond with the times that the system has rebooted under the Application or System windows logs?
    Chris
    Mar 30, 2012 2:22 PM   in reply to skrobbs
    I have the exact same issue. 3 times the computer just froze, and one time it blue screened. I won't be doing anything and my firewall will ask for access to some flash update through the website akamaitechnologies.com (or something close to that). If I don't allow or deny the request nothing goes wrong, but if I do allow or deny it my computer crashes. The IP of the reqesting address is 184.29.210.70, if it helps.
  • Chris Campbell
    May 4, 2010
    Mar 30, 2012 2:38 PM   in reply to t3hnuub
    Thanks for the feedback.
    Can you both send me your FlashInstall.log?  You can reach me at ccampbel@adobe.com.
    Do you recall if you used the default option to enable automatic silent updates when you installed 11.2?  If so, could you open your mms.cfg file (found in the same location as the FlashInstall.log) and add the following line:
    SilentAutoUpdateVerboseLogging=1
    Then, let the computer run for an hour (or until the next crash) and grab the FlashInstall.log again and send it my way.
    Chris
    Mar 30, 2012 3:11 PM   in reply to Chris Campbell
    Email sent. I rebooted and tried to change the file, but I get an "Access is Denied" error.
  • Chris Campbell
    May 4, 2010
    Mar 30, 2012 3:19 PM   in reply to t3hnuub
    Thank you for the log.  What virus scanner / firewall do you guys have installed?
    Chris
    Mar 30, 2012 3:21 PM   in reply to Chris Campbell
    ESET Smart Security.
  • Chris Campbell
    May 4, 2010
    Mar 30, 2012 3:50 PM   in reply to t3hnuub
    t3nuub,
    Are you also using Firefox?  Could you make sure both the IE and the "Other browser" installs are done.  We're trying to pinpoint if it's an issue with ESET crashing when downloading our installer or simply our xml.
    Chris
    Mar 30, 2012 3:59 PM   in reply to Chris Campbell
    I am using Firefox. I downloaded and tried to install the 64 bit Flash Player for ActiveX (Internet Explorer), but while installing my computer blue screened. I'll try to install again and change this post if it does not crash or BSOD.
  • Chris Campbell
    May 4, 2010
    Mar 30, 2012 4:23 PM   in reply to t3hnuub
    If you're unable to install, could you try disabling ESET?  If it works with ESET disabled, please check to see if they have an update available.
    Chris
    Mar 30, 2012 4:38 PM   in reply to Chris Campbell
    I disabled ESET and attempted to install it, but I got a blue screen with the error message BAD_POOL_CALL or something similar. After the reboot I checked ESET for updates and it says it is up to date.
    I just checked to see if Windows 7 is up to date, and it is not, so I will install these updates right now.
    Mar 30, 2012 7:01 PM   in reply to t3hnuub
    Okay. I managed to finally get both 64 bit versions installed. (edit) - It still crashes, but now ESET does not notify me about any update checking; it just plainly freezes. -
    First I attempted to install the Windows 7 Service Pack 1, but I have a different issue with that which I won't go into much detail about, but it was a failed attempt. I thought about it for a bit, and decided to install IE9, so I downloaded the .exe from Microsoft and attempted to install it, but I got a BSOD.
    I went into safe mode with networking, went to the programs list in the control panel, and uninstalled everything related to Adobe Flash Player. I then installed IE9 through their website download. I restarted and again booted in safe mode with networking to install the 64 bit Flash Player for ActiveX (Internet Explorer). Installation was just fine for that, so I rebooted in safe mode with networking again just to be safe to install the 64 bit Flash Player Plug-in (All other browsers) and all was well. I booted up my computer normally and checked youtube videos on both IE9 and Firefox, and all is well.
    On the reinstall I chose the option to notify me before installing any updates.
    EDIT: After this recent freeze, I'll be continuing to install Windows 7 updates through safe mode.
    Mar 30, 2012 7:38 PM   in reply to t3hnuub
    I suggest you run the SFC: http://support.microsoft.com/kb/929833
    Mar 31, 2012 8:52 AM   in reply to Carl E. Myers Jr.
    100% verified. No problems there.
    I've completely uninstalled ESET and updated Windows. My computer has been up for about an hour and it hasn't crashed. I guess the problem is more with ESET on my end. Thanks for the help.
    I just went back to the ESET website and it turns out they're up to version 5.*. I was running on version 4, yet when I ran the update it definitely said I had the most up to date version installed.
    Mar 31, 2012 7:25 PM   in reply to skrobbs
    Hi skrobbs,
    Could you tell us what anti-virus and/or firewall you're using?
    Apr 1, 2012 1:29 AM   in reply to skrobbs
    Exatly same problem in here first I get a short green screen, after that everything crash and goes to the blue screen.
    All drivers updated and I could not browser or use the computer after instal.
    Have to unistall flash in safe mode to use my computer again.
    what are the ideas ?
    Apr 1, 2012 1:45 AM   in reply to w 7 64 bit
    Hi w 7 64 bit,
    Could you please share the name of your anti-virus and firewall, if any?
    Stephen
    Apr 1, 2012 2:15 AM   in reply to skrobbs
    Mcafee
    Apr 2, 2012 6:49 AM   in reply to skrobbs
    I ran across a client having a similar issue this morning.  Her system was consistently bluescreening at 20 past the hour all day on 3/31.
    I checked and found that the adobe flash updater was scheduled to run at 19 past the hour.  When I tried installing the update manually from the Adobe website, it bluescreened as well.
    Disabling the update task has stopped the crashes for now, but still leaves the root cause unidentified.
    She had not experienced this issue before 3/31.
    We are using ESET for antivirus, so it's possible there's an issue with one of their definition updates from this weekend.
    Apr 2, 2012 12:23 PM   in reply to skrobbs
    Hi, after last update installed, same problem here. When computer is idle for aprox. 20 minutes, BSOD happen. Windows 7 / 32bit, ESET NOD 32 (4.2.58.5).
    Apr 2, 2012 3:32 PM   in reply to slavotom
    For those of you using ESET Version 4, try downloading version 5 from their website. That fixed my issue. I contacted their customer support about the problem and have yet to get a response.
  • Chris Campbell
    May 4, 2010
    Apr 3, 2012 5:19 PM   in reply to t3hnuub
    Thanks for the heads up on version 5.  Has anyone else tried updating to see if this resolves the problem?
    Apr 4, 2012 2:29 PM   in reply to skrobbs
    I have not been able to install SP1, but for reasons ESET isn't causing. I also used to have that freeze up at 15%, and after some research I found out ESET was causing that issue. If you have ESET uninstalled you shouldn't have issues installing SP1. When I try to install it with or without ESET 5 installed I get error_not_found 0x80070490. I think it's because of the last failed attempt to install it.
  • Chris Campbell
    May 4, 2010
    Apr 5, 2012 11:18 AM   in reply to skrobbs
    Thanks for updates.  Please keep them coming.
  • Chris Campbell
    May 4, 2010
    Apr 6, 2012 6:25 PM   in reply to Chris Campbell
    I've received word from ESET that this is a known issue.  Systems which have their latest business version 4.2.76 or the latest home version 5.x will not crash with Flash Player's automatic update service.
    Yesterday, an automatic program component upgrade was also made available for older versions.  For more information, please see the following KB article:
    http://kb.eset.com/esetkb/index?page=content&id=SOLN2981
    Chris
