Im new to Flex, and I got some problem with this code.
The problem is the "NewValue" I want to be updated thru UDP, any help?
<fx:Script>
<![CDATA[
import be.aboutme.nativeExtensions.udp.UDPSocket;
import flash.events.TimerEvent;
import flash.utils.Timer;
import mx.collections.ArrayCollection;
import mx.events.FlexEvent;
private var udpSocket:UDPSocket;
protected function applicationCompleteHandler(event:FlexEvent):void
udpSocket = new UDPSocket();
udpSocket.addEventListener(DatagramSocketDataEvent.DATA, udpDataHandler);
udpSocket.bind(1000);
udpSocket.receive();
protected function udpDataHandler(event:DatagramSocketDataEvent):void
try
var o:Object = event.data.readObject();
switch(o.command)
var NewValue = new o:Object; <---------- HERE!
[Bindable]
public var myArray:ArrayCollection = new ArrayCollection();
public function initTimer():void
var myTimer:Timer = new Timer(100, 0);
myTimer.addEventListener("timer", timerHandler);
myTimer.start();
public function timerHandler(event:TimerEvent):void
var obj:Object = new Object();
var NewValue;
obj.time = getTimer();
obj.Value = NewValue; <---------- HERE!
myArray.addItem(obj);
</fx:Script>
Your syntax looks funny to me.
I am not familiar with that approach.
Following are some suggestions.
try something like
var NewValue = o;
or if you are trying to typecast then
var NewValue = o as Object;
or
var NewValue = Object(o);
also it looks like you are missing the 'catch' part of the 'try / catch' structure.
try
... some code here
catch (err:Error)
... handle error here if it happens
I hope this helps you a bit.
