Anissa22m
Missing templates in the print module of Lightroom 3.
Mar 30, 2012 9:58 AM
I'm running the most updated version of Lightroom, but I am missing the templates under the Print Module. I've read other posts that mention the same issue, but there is no mention as to how or if the problem was fixed. Anyone know what to do?
    Mar 30, 2012 10:10 AM   in reply to Anissa22m
    Which templates are missing?
    Default Lr templates or the user templates that you created?
    Mar 30, 2012 3:33 PM   in reply to Anissa22m
    OK. Which templates - in which Module?
    Develop Module, Print Module?
    Where were you looking for the templates?
    Mar 30, 2012 3:50 PM   in reply to Anissa22m
    Sorry, I hadn't read the header of your post. So, OK, you miss the Print Templates.
    Can you not see them on the left side of the Print Module? Are they maybe not expanded?
    This is what they lookl like if not expanded.
    You then have to click on the small triangle to expand them. Then they look like this:
    Apr 3, 2012 8:38 AM   in reply to Anissa22m
    Anissa22m,
    You wrote: "when I click on Lightroom Templates to expand it... nothing drops down"
    There's something definitively wrong here; you should see the list as in my previous screen shot.
    You might have to un-install and re-install Lr. Before you do that make a note of the name and location of your catalog file, so that you can load it once Lr has been re-installed.
    Open Lr and go >Edit >Catalog Settings >General tab. There it tells you the name and location of your catalog file. If you click on <Show> you will be taken directly to the location. The catalog is the file ending in < .lrcat>. Make a note of its exact name and location. Then close Lr and in your OS proceed to uninstalling LR.
    After the re-installation of Lr go >File >Open catalog and navigate to the location of your catalog. Lr will then open with your catalog created before the un-install.
    Before you do the un-install and re-install you might try to delete and replace the Preference file. This file sometimes gets "funny" which results in all kinds of weird behavior in Lr.
    See here how to delete and replace the Preference file: http://lightroomers.com/replacing-the-lightroom-preference-file/745/
