abssiddiq
Frame Options
Mar 30, 2012 6:53 AM
Hi Guys,
I have attached the screen shot below.
I could not able to move the Head close with the Frame. I have checked the Frame Options it is set as Top.
I dont need the above space between frame and text
Siddiq
    Mar 30, 2012 6:58 AM   in reply to abssiddiq
    Check the paragraph style applied on the Heading ,
    Under "Indents and Spacing" , check for the "Space before" , change it to zero and you will be good to go.
    Mar 30, 2012 7:27 AM   in reply to abssiddiq
    Can you go to Type>Show hidden character and then provide the screen shot
    Mar 30, 2012 8:26 AM   in reply to abssiddiq
    If you're using a Paragraph Style on the head, check the style's definition. Under Indents and Spacing, is "Align to Grid" set to None?
    Mar 30, 2012 4:08 PM   in reply to abssiddiq
    Space before is ignored at the top of a column, so that's irrelevant. In addition to Mary's suggestion, look at the frame options and see if there is a top inset applied, and also check the Baseline Options tab in the same dialog to be sure it ins't set to some fixed amount that is pushing the line down.
