na mara
help,how to expand a path of a circle,
Mar 31, 2012 2:11 PM
Hello,
i would like to know how to increase the size of a cog wheels,the outline is a path,
thanks,
    Mar 31, 2012 2:18 PM   in reply to na mara
    Er... Scale tool?
    But your Illiespeak is way out.
    Mar 31, 2012 2:26 PM   in reply to na mara
    na mara,
    Did you read the answers to your more specific thread?
    http://forums.adobe.com/message/4298514#4298514
    Hi Steve.
    Mar 31, 2012 6:49 PM   in reply to na mara
    I believe I gave you sure fire way of doing this and controlling it in the future for this very reason, but this is the method I would use to both crete the cogged wheel and to be able to change it at will without redrawing it or deleting any thing just change the settings in The Effects>Distort and Transform>Transform you can change it to how many cogs you want just changge the umber of copies  and the change the other settings to accommodate the change.
    Mar 31, 2012 8:37 PM   in reply to Wade_Zimmerman
    Except if you go back and read the original question you will see that it was clearly stated (and shown in the screenshot) that after every six normal teeth, there followed two differently-shaped teeth. Your method, unfortunately, ignored this specification.
    Apr 1, 2012 6:41 AM   in reply to DayForce
    I don't know if there's a formula for producing regular polygons of the same side length and with the number of angles as a variable.
    If so it would certainly simplify the drawing of gears.
    Anyone? Jacob maybe?
    Apr 1, 2012 6:46 AM   in reply to DayForce
    DayForce
    If you look at this thread it says nothing about such a requirement, I am explaining to the OP how to control the artwork. With a little imagination and a little reading of what these features and how Illustrator works  the requirements you refer to is a simple task.
    Perhaps you can figure it out?
    I can.
    The OP has the tools to do this and the knowledge has been given them in several forms now all they have to do is think a little bit and the answer will come to them immediately as it should to you by now.
    Apr 1, 2012 10:07 AM   in reply to Steve Fairbairn
    A few years ago, I wrote a simple Javascript for exactly that. Quickly defines a regular polygon by desired side length.
    But one can do much the same thing a little less quickly (Illustrator's rounding errors notwithstanding) by:
    (SmartGuides on)
    1. Polygon Tool: Click. In the dialog, specify the number of sides.
    2. WhitePointer: Select one segment. Copy. PasteInFront.
    3. Document Info palette: Note the length of the pasted segment.
    4. DoubleClick the Scale Tool: Key the desired value into the Uniform field, followed by two zeros and a division mark, followed by the value noted in the Document Info palette. Click OK.
    5. Select the whole polygon. Transform Again. (Ctrl D).
    The trick would then be to replace each segment with the desired path. Several scripting approaches could be used for that. (I'd likely use a modification of my ReplaceWithSymbol script--complicated by Illustrator's insistence upon dimensioning Symbols by their preview bounds.)
    But you can accomplish all this with Transform Effect:
    1. Draw the tooth in a horizontal orientation, with the tooth pointing downward.
    2. Control Panel: Select and copy the value in the Width field.
    3. Effect>Distort & Transform>Transform.
    Set the 9-point transformation center icon to lower left.
    Paste the value into the horizontal Move field. (There should be a Percentage Of Original toggle for these fields, just as there should be Absolute size fields in Transform Each.)
    Copies: Enter one less than the number of teeth desired.
    Rotate: Enter "360/", followed by the number of teeth desired.
    But the reason I have not responded to this thread until now is that the original question is too poorly stated. If this is for illustration purposes only, a Pattern Brush (using Approximate Path for the Fit option) should do fine. But Pattern Brushes do "wedge" distort their side tiles, so if this is actually needed for geometric accuracy, the Pattern Brush would not serve. And if dead-accuracy is, in fact, needed (as if for an actual working drawing for manufacturing), other considerations may come into play. For example, the actual shape of sprocket teeth may be required to change dependent upon how many teeth are on the sprocket. (The countershaft sprocket and rear-wheel sprocket of a motorcycle fit the same chain; but the shapes of their teeth differ slightly because the chain runs in a much tighter bend around the countershaft sprocket.)
    JET
