I have a quick question about a simple captivate project. I created a project with only powerpoint slides (no animation) and with some audio. However I takes a very long time to load the course. Much longer than my other "more complicated" captivate projects. While the file size is only 10Mb (half the size of the other projects).
The course should start after downloading 5% of the file (Settings: Start-End, Pre-loading = 5%), but still no results.
Let me know if you are interested in a quick look….Any idea why this take so long?
The Flash player version you publish to is determined by your target audience and what they are using. It's less of a question about which is the "best version". Usually, the later versions will have speed improvements etc, but if your users don't have those versions then you would be forcing them to upgrade in order to see content. In some corporate settings the end users may not have permissions to change or update their Flash Player version. Know your target audience.
Hi RodWard,
Thanks for the tip. But what about the issue with my project. If the flash version is not the problem what else can slow down the startup time of a published course? The file size is 10Mb and it should start after downloading 5%, but with my highspeed boardband internet is still takes 4 minutes to start. While other projects with double the file size only takes a few seconds.
Stan
Tell me more about what this project contains. Are there any videos, SWF animations, Question Pools? If you have voiceover audio, was it added separately slide by slide or to the project and then synced up to slides?
Are there any widgets or other components?
Are there heavier graphics or introductory videos near the beginning of the course module?
Does it load up and play immediately when you run it from your own PC drive, or is there a slight lag when compared to the other projects you mention?
Are all of these other faster projects constructed and structured the same way as this one, or is there something different about the one that is slow?
I get the feeling that there is something more in play here than just the size of the project.
Hi Rodward,
It's a powerpoint project. No animations nor videos. Just audio and nothing special. That is why I am so confused about the time it takes to start. I have made several more "complexed" courses with twice the size and without any issues. If you like you can download the project from here and take a look.
I would highly appreciate it..
Link: http://www.nomoneylaundering.com/downloads/elearning/AMLAwarenessv4.cp tx.zip
If you have audio on some of your slides and the audio plays at the beginning of the timeline on that slide, it doesn't matter what your preload is set at...the file will NOT load until 100% of the project has been buffered since it has audio playing at the start of the slide(s).
On the slides with audio...move the start of the audio on the timeline to .1 (just drag it back a TINY bit) and then resave and republish with the preloader set where you want it. That should help. Once someone gave me that advice, my files started loading MUCH faster. Let me know if you need further instructions and I can take some screen shots.
Good luck!
Below you will find my settings. Nothing unusual...
Your version of Cp5 is later than mine, and mine doesn't have this issue.
Which particular preloader are you using in your project? Have you tried just using the default.swf preloader?
Have you tried uploading your content to a totally different web server to see if the same content performs differently? For example, try SCORM Cloud and see if the same or a different preloader works from there. Your issue might just be your current web server environment.
Yes, it works.
I was using a preloader from the web for my e-learning courses. No issues before, but when I used the powerpoint import feature I had a very long start up time. Now I switch to a default preloader from the Captiva gallery folder and it seems that the course starts immediately.
Don't now why but it seems to solve my problem.
Stan
OK. Please mark this thread as Answered then so that other users will know where to find a solution.
By the way, another little gotcha with preloaders is that if you transfer your project file from one computer to another, and the path shown to the preloader under Preferences > Project > Start and End is NOT exactly the same, then Captivate will not be able to find the preloader file at publish time and will not be able to include it with the output files. This can mean that your preloader simply does not appear and your project load time will suffer because basically you are getting no preloading at all.
I found this out the hard way when I transferred a project file from my 64bit computer to a 32bit computer and the preloaders tanked. The file path was looking for them in a non-existend Program Files (86) directory (as found on 64bit systems running 32bit apps), whereas the current 32 bit PC only had a Program Files directory.
