Hello,
I would like to save metadatas (for example keywords) inside the RAW files, and not in external .XMP sidecar file.
How to do this in Lightroom ?
Josh
PS: is XMP a file format (= .XMP files) or a metadata format that can be embedded either in a .XMP sidecar file or in the RAW itself ?
You can't save metadata directly to the raw file in Lightroom. You can only save it to an XMP sidecar file - a text file with XMP as its file extension and containing data that is written in XMP format.
To avoid sidecar files, consider converting your raw files to DNG. Metadata is written to these files in XMP format, but within the DNG.
Clearer?
1) Is the RAW to DNG conversion destructive or not ?
(ie if I delete the original RAW, and I keep the DNG only, can I recover the original RAW later ?)
2) Antother thing :
The fact that it's impossible to store keywords INSIDE raw files is VERY annoying.
If I put keywords with Lightroom, NO OTHER software will be able to see these keywords.
(For example viewers like Picasa, XnView, or other non-Adobe softwares etc. don't see .XMP sidecar files , and thus don't see keywords).
Any solution for that problem ?
I don't want to spend countless hours to add keywords, and then notice that the keywords only work in LR ![]()
Do you think it's wise to write keywords into proprietary files whose format is not publicly-available? That's why it's like this, and there are plenty of painful examples of things going wrong.
All the raw file's data is taken to the raw file. If you want to reconstitute the raw file itself, either include the raw file in the DNG (the DNG converter can extract it later) or save the raw file in a secondary archive and treat it as extra backup.
I use PhotoMechanic to keyword my nef files, and I use ExifTool/ExiftoolGUI to transfer gps and location data from xmp files to my nefs (after geolocating in LR). I then delete the xmp files after the transfer. So it can be done, but not within LR. I check the altered nefs in NikonView afterwards; if it opens them they are OK.
Bob Frost
But the keywords put with Lightroom (and saved in .XMP files) won't be seen by any other software than LR or other Adobe softwares!
This simply isn't true. There are a lot of non-Adobe software that will recognize keywords in .xmp files. I would imagine that almost all photographic software will recognize them.
I just did a small test :
I converted one of my .PEF (Pentax) RAW file into DNG. The keywords are now stored INSIDE the DNG.
But no other software is able to see these keywords :
* XnView is unable to see them
* Picasa : idem
* PhotoME (well known for its ability to see metadatas in a file!) : idem : impossible to see these keywords.
Is it normal that no other software than LR can see keywords stored inside a DNG file ?
THanks
* Picasa : idem
THanks
well acdsee, exif tool and even the windows explorer can see them (windows explorer maybe because i have an extra RAW viewer plugin installed.. im not 100% sure).
photome.. mhm.. just tried it... crashes here whenever i want to open an DNG file. not very convincing. maybe because it´s a beta.
i read (not tested by me) the following tools support XMP data in DNG
irfan view + plugin maybe?
Make sure you are updating the dng files with the metadata either by Command (Mac) / Control (Win) + S or Catalog Settings > Metadata > Automatically Write Changes into XMP
It's a horridly named catalog setting since if you are using DNG you don't have XMP files but it does the same thing, it updates the dng with the catalog settings.
XMP does not mean XMP FILES per se.
XMP is a metadata format/standard. so it´s not horrible named but simply missunderstood. ![]()
http://en.wikipedia.org/wiki/Extensible_Metadata_Platform
XMP can be used in several file formats such as PDF, JPEG, JPEG 2000, JPEG XR, GIF, PNG, HTML, TIFF, Adobe Illustrator, PSD, MP3, MP4, Audio Video Interleave, WAV, RF64, Audio Interchange File Format, PostScript, Encapsulated PostScript, and proposed for DjVu. In a typical edited JPEG file, XMP information is typically included alongside Exif and IPTC Information Interchange Model data.
catalog settings.
Not really horrid - it does update the xmp storage part of a dng file. My
nefs, jpgs, tiffs, and psds all store xmp metadata alongside the exif, and
iptc metadata.
Bob Frost
