gottothinkpositive
surface blur slow
Apr 1, 2012 4:46 PM
So i was pretty excited cause surface blur was super fast when i first tried cs6...takes 5 min run time for me now in cs5... but its slow like in cs5 now. any ideas?
  • Noel Carboni
    Dec 23, 2006
    Apr 1, 2012 5:06 PM   in reply to gottothinkpositive
    Check your GPU settings in Preferences - Performance.  I believe Photoshop is adaptive, meaning if it encounters problems in your display driver it might reconfigure itself not to use the GPU in the same ways it originally tried.
    If it's deconfiguring use of of your GPU, perhaps you need an updated display driver on your system.
    What computer, OS, and video card do you have?  For PCs the manufacturers all release new drivers fairly frequently.  For Macs the display driver updates come with OS updates from Apple.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Apr 1, 2012 7:36 PM   in reply to gottothinkpositive
    Did you check in Photoshop's Preferences - Performance menu as I mentioned to see if the GPU has been disabled?
    -Noel
    Apr 1, 2012 8:03 PM   in reply to gottothinkpositive
    When Noel mentioned the video card, he meant what video card is in your computer driving your display rather than if you are using a camera card to access your photos. Your problem may very well be GPU related.  See this link to GPU issues and supported video cards.
    http://forums.adobe.com/message/4289204#4289204
    Please verify that the video card in your computer is on the list of those supported and visit the web site for the manufacturer to be sure you have a current driver.
    Then, try changing the settings mentioned and follow the GPU troubleshooting suggestions.
    Let us know how it goes.
    Pattie
    Apr 1, 2012 8:05 PM   in reply to gottothinkpositive
    Looks like we were posting at the same time- I'm glad you got it working
    Pattie
    Apr 1, 2012 8:20 PM   in reply to gottothinkpositive
    First you should verify the video card and driver and the settings mentioned in the  GPU link. Let us know what you find after checking those.
    Pattie
  • Noel Carboni
    Dec 23, 2006
    Apr 1, 2012 9:04 PM   in reply to gottothinkpositive
    Note that it says ATI Radeon 4670 - that's your video card.
    -Noel
    Apr 2, 2012 1:19 AM   in reply to Noel Carboni
    you can read in this FAQ how to get to the system information and cut and paste it into the reply:
    Pattie
    FAQ: How do I share my System Information?
  • PECourtejoie
    Jan 11, 2006
    Apr 2, 2012 1:22 AM   in reply to gottothinkpositive
    Yes, do check your GPu information in Help>system info, you might be running an old driver. Normally, using the GPU makes things faster, unless the driver has an issue, or the card is seriously underpowered.
    Apr 2, 2012 3:07 AM   in reply to PECourtejoie
    Surface blur is not GPU accelerated! Are you talking about one of the new blur filters? Only those are.
    Apr 17, 2012 2:36 PM   in reply to gottothinkpositive
    I see your use graphics processor is not checked. If you are able to run when you check it,  try it using these different settings to see if one works better for you:
    Pattie
    Choose Edit > Preferences (Windows) or Photoshop > Preferences (Mac OS).
    In the Performance panel, make sure Use Graphics Processor is selected in GPU Settings.
    Click Advanced Settings and specify one of the following options:
      • Mode > Basic
      • Mode > Normal
      • Mode > Advanced Provides the benefits of Normal mode as well as newer OpenGL advances that can result in improved performance.
    Apr 17, 2012 2:50 PM   in reply to klsteven
    i wonder too.... (unlikely he speaks about the new blur filters in CS6 because he compares it to CS5).
    anyway, if it is about the SURFACE BLUR filter (like the topic says).... keep in mind surface blur is quite fast on 8 bit images but very slow for 16 bit images.
    that maybe explains the speed differences you noticed.
    from my experience nothing has changed for the surface blur filter... it is as slow in CS6 as it was in CS5.
