Vilius Šumskas
how to disable progressive downloads
Apr 1, 2012 11:34 PM
Tags: #download #progressive
We have FMS interactive configured to do RTMP and HLS streaming. However the clips still can be downloaded through http://domain.name.com/vod folder. Is there a way to disable progressive downloads? While at it is there a way to disable HDS also? I want to allow HLS and RTMP only.
    Apr 2, 2012 1:39 AM   in reply to Vilius Šumskas
    Reason for your data available for progressive dowload is because its there in webroot. Webroot/<extendend-path> is by default available to any client via http://server-name/<extendend-path> unless you have taken measures to protect it inside Apache's httpd.conf.
    You can do one thing. Keep your content outside Apache's webroot. Say C:/myvideos/. for example there is a video there sample.f4v i.e C:/myvideos/sample.f4v
    Now you can change the location "HttpStreamingContentPath" pointing to from "../webroot/vod" to "c:/myvideos/" under hls-vod inside httpd.conf (Apache/conf)
    <Location /hls-vod>
        HLSHttpStreamingEnabled true
        HLSMediaFileDuration 8000
        HttpStreamingContentPath "C:/myvideos/"
        HLSFmsDirPath ".."
        HLSJITConfAllowed true
       Options -Indexes FollowSymLinks
    </Location>
    Or you can disable(modify) content availibilty by making appropriate changes unders in httpd.conf
    <Directory "../webroot">
        AllowOverride None
        Order allow,deny
        Allow from all
    </Directory>
    To disable HDS-Live, set "HttpStreamingEnabled" to false under hds-live location directive
    <Location /hds-live>
        HttpStreamingEnabled false
    To disable HDS-vod, set "HttpStreamingJITPEnabled" to false under hds-vod location directive
    <Location /hds-vod>
        HttpStreamingJITPEnabled false
    To disable HDS-vod offline fragmented content, set "HttpStreamingEnabled" to false under vod location directive
    <Location /vod>
    You need to restart the Apache server after making the changes to get them reflected next time..
    Hope it help
    Apr 2, 2012 1:56 AM   in reply to Vilius Šumskas
    I guess, yes .. but it may deny all request to webroot.. Even everything beyond FMS usage like your own hosted pages, FMS default index.html will not be allowed.. I hope you underrstand what all you are restricting as per your usage/requirement..
    Apr 2, 2012 2:14 AM   in reply to Vilius Šumskas
    In that case just change HttpStreamingContentPath to correct location of the media folder under hls-vod tag. like this:-
    <Location /hls-vod>
        HttpStreamingContentPath "<application-folder-path>/vod/media"
        HLSFmsDirPath ".."
    </Location>
    Restart Apache.
