SWF generated by Ant script
Mar 30, 2012 6:47 AM
I am creating a SWF file using an Ant script. It is a working application. No problem running from FB or using ReleaseBuild.
But the one created by the script is not running. All I get a white Flash Player screen. Is there any way to trouble shot this problem?
How would I know what exactly is wrong?
    Apr 1, 2012 11:20 AM   in reply to Zolotoj
    What does your ant script look like?  Are you compiling with RSLs?
    Apr 2, 2012 10:42 AM   in reply to Zolotoj
    Does it help if you change this:
    <static-link-runtime-shared-libraries>false</static-link-runtime-share d-libraries>
    To this:
    <static-link-runtime-shared-libraries>true</static-link-runtime-shared -libraries>
    Apr 2, 2012 11:54 AM   in reply to Zolotoj
    What's the file size of your output swf?
    Calculating status...
    Apr 3, 2012 6:57 AM   in reply to Zolotoj
    1. Make sure you compile via ant against the same SDK as you use to compile from FB.
    2. Enable loggin in your application + filter nothing and fireup SOSLogger see what it prints.
    3. Make sure you use the same FP version when you run from FB and from ANT.
    4. Make sure you don't have flash preloaders interfering with your application.
    5. Check your computer for viruses
    6. Try to reboot
    GL.
    Apr 3, 2012 11:00 AM   in reply to Zolotoj
    That looks like a signed RSL.
    Apr 3, 2012 12:06 PM   in reply to Zolotoj
    My first guess was that you don't see the SWF because some RSLs aren't loading properly, but you claim that you aren't using RSLs.  The message above seems like RSLs are actually being used in some way, so you'll want to figure out why that is.
    Maybe try setting <static-link-runtime-shared-libraries></static-link-runtime-shared -libraries> to true in your /path/to/FlexSDK/frameworks/flex-config.xml  file?
    Apr 3, 2012 1:39 PM   in reply to Zolotoj
    7. Try your swf on antoher machine
    SOSMax logger: http://www.sos.powerflasher.com/
